Author Topic: cb500 rearsets  (Read 11615 times)
Offline ben.cb500
Re: cb500 rearsets
« Reply #25 on: August 17, 2011, 08:02:01 PM »
...anyone know if the rearsets from Fast From the Past will work with the stock exhaust?
I have actually been using the passenger pegs as I find the position better for my back for some reason.....maybe a time to invest, although they dont trail back that much??
http://www.fastfromthepast.com/servlet/the-112/Rearsets--Fixed-Rubber/Detail
Offline IndyFour
Re: cb500 rearsets
« Reply #26 on: August 18, 2011, 05:41:49 AM »
Yes, they should work with the stock exhaust.  The only complication I can think that you may have is that the bolt that is included with the rearsets may not be long enough to go through the rearset bracket, frame ear, and two exhaust brackets (since the stock exhaust has two brackets on each side of the bike).  It may be long enough, though.....I don't recall at the moment.  If not, it's just a matter of getting a longer bolt.
If you take your tow and put it on the front peg and then set your heel on the passenger peg (if your feet are long enough to do that), that's about where your feet will be with the rearsets (approx).
Good luck!
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline jayb2664
    • My YouTube Channel
Re: cb500 rearsets
« Reply #27 on: September 07, 2011, 01:23:24 PM »
Yes the set (Tarozzi) from Fast From the Past works fine on 1971 CB500. Stock exhaust and retained passenger footpegs. Uses longer bolt for this. I think it is a quality setup and straight up bolt on.
CB400 CB500 CB550 rear sets rearsets tarozzi fast from the past
« Last Edit: September 21, 2011, 08:55:08 AM by jayb2664 »
71 CB500 K0 slightly tweaked
70 CB750 K0 'barn find' waiting for inspiration
Offline isred09
  • you meet the nicest people riding a honda
Re: cb500 rearsets
« Reply #28 on: September 09, 2011, 09:23:06 AM »
I cannot believe moons has suggested the cb400 rear sets.they need a little modification an u do use the later cb550f kickstsrt lever. Do a search an u will find the how to with picks.
 Brent
