Author Topic: My new Cb550k - Father and Son project  (Read 5403 times)
Offline Bellard
« on: June 10, 2011, 06:51:28 PM »
Ok so this is a Father son project bike. I the Son know a little more about engines then father does. But this is my dads bike. My bike is the Cb350k3 Twin i bought a month or so ago. We both live in Va We picked this bike up from a very nice man near by. Luckily we picked her up at a great price. Anyways Any advice or wisdom u guys have to helping me on my path would GREATLY be appreciated.  Anyways so far Ive tryed to clean the carbs and the way it looks 1st carb was Damn clean 2nd little bad... 3rd little worse then second and full of gas even with drain open. and forth bad.. 2 3 and 4 main jets were clogged. Wheres the slow jet i see a thingy above the main jet is this the slow jet.. Can it be removed and cleaned? Ive tried to remove the diaphragm needle but its connected somehow. Is there a guide on this site to show me how to dismantle it? ive looked at the manual a little not much help. Including some pictures.. The carb looks likes its been rebuilt a little.
Thanks.
-Corey
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bellard
Re: My new Cb550k - Father and Son project
« Reply #1 on: June 10, 2011, 06:54:55 PM »
Clogged main jets
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #2 on: June 10, 2011, 08:03:05 PM »
Welcome! It sounds a great project for both of you.
As for the carb rebuild, there's some good info in the Carb FAQ. I think there may be a rebuild guide there. Your questions are pretty specific, so if the FAQ isn't a help, you would prolly do best to start a thread in the Tech forum because the carb gurus prolly won't see your question here.
Oh, and post pictures of your bikes if you can.
Quote from: SOHC Digger, RIP
'77 CB750k
Offline Bellard
« Reply #3 on: June 12, 2011, 05:01:21 AM »
Ok so far ive went out worked on the carb. Ive removed a couple of peices from the bike to spit shine :). I took off the muffler to Inspect it and clean it up. To my suprise i found in my 4 in 1 A Small hole right at the main connection for all 4 pipes major rust and a big black mark under neither engine. There was no engine melting or anything that god. I also noticed something about the carburetor. Correct me if im wrong but theres suppost to be (4) diaphragm adjustment dohickys i only see 3 of the 4. I will post more pictures.
First picture is of bike Gas tank and side panels not on (put up for protection) Gas tank is a bit rusted up.
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bellard
« Reply #4 on: June 12, 2011, 05:03:03 AM »
More pictures
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bellard
« Reply #5 on: June 12, 2011, 11:20:45 AM »
Ok so today I ripped off those Ape hangers.. and put on my spare Shortys
« Last Edit: June 12, 2011, 11:23:26 AM by Bellard »
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline MasterChief750
  • Detonation
« Reply #6 on: June 14, 2011, 03:19:34 AM »
just a heads up if you take off the choke butterflys those screws are one time use, they are flared at the end and you may get a couple back in but you could end up breaking off  some when you go to put them back in
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Bellard
« Reply #7 on: June 14, 2011, 04:20:52 AM »
I wasn't going to they seem fine and to my knowledge the only thing that can be harmed due to Carb cleaner is the top felt gasket correct me if I'm wrong though please!  :)
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
  • Detonation
« Reply #8 on: June 14, 2011, 04:29:35 AM »
you should be fine if the top gasket is removed/replaces before or after cleanin respectively
I AM THE STIG
Sam is THE STIG
Offline Bellard
« Reply #9 on: June 14, 2011, 04:36:28 AM »
Thanks bud just being safe :)
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bellard
« Reply #10 on: June 15, 2011, 07:39:37 AM »
Ok updating the gas tank was a bit rusty with four pounds of rust in it.
My dad shook her clean while I got the electrosis ready.
at this point its doing its magic cleaning her every few hours.
Were going to repaint it to give it its Kent brown look again. Does anyone know of any paints I can buy that's close to this color?
Thx
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #11 on: June 15, 2011, 08:25:20 AM »
Nice. Put your pa on the heavy lifting parts. ;-)
'77 CB750k
Offline Bellard
« Reply #12 on: June 15, 2011, 08:30:01 AM »
Heavy lol not heavy :) I had to carry 5 gallon bucket lol
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bankerdanny
  • Endeavor to persevere
« Reply #13 on: June 15, 2011, 11:18:34 AM »
When you ask carb questions, make sure that the year of your bike is stated (I just list mine in my signature) because all 550's don't have the same carbs.
Offline Bellard
« Reply #14 on: June 15, 2011, 11:25:16 AM »
Sorry thought I did must have not it accept she's there now
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bankerdanny
« Reply #15 on: June 15, 2011, 04:13:28 PM »
Better, I have the same bike and just refreshed my carbs (new gaskets only) a couple months ago so they are still relatively fresh in my mind.
Offline Bankerdanny
« Reply #16 on: June 15, 2011, 04:16:24 PM »
The manuals are VERY unhelpful with this carb. The Haynes manual doesn't include a single picture of this setup or even address that the 77-78 K bikes have different carbs from the 76 and earler K's and all the F bikes.
I know it's too late, but pre-dissasembly phots can be very helpful. I you like I can e-mail some of the ones I took, but I probably won't be able to get to it for a few days.
Offline Bellard
« Reply #17 on: June 15, 2011, 05:43:28 PM »
Thank you guys for following my project I bought a lift today. For 250
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bankerdanny
« Reply #18 on: June 15, 2011, 07:28:56 PM »
I envy you. I have my eye on a couple Goldwing project bikes and I may have to break down and get a lift.
Offline Bellard
« Reply #19 on: June 15, 2011, 08:02:15 PM »
Ya there really better on the back.. Easier to change a tire too! :)
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline db22
  • Old and in the way.
« Reply #20 on: June 16, 2011, 04:23:29 AM »
Corey -- Here's what I learned about jets for PD carbs, being a total newbie.  The main jet proper is just a tiny thing screwed into the emulsifier tube.  Your picture of clogged jets shows the jets and tubes still screwed together.  If you need to replace your main jets, very carefully unscrew the jet (the slotted part on the tip) from the tube.  That's the replaceable part.  Be careful of the tube -- they're hard to find.  A 7mm wrench fits the flats on mine.
Slow jets are the brass cylinders between the main jet in the middle and the external air screw.  On my carbs, the originals were a press-fit, but as far as I know, those are no longer made.  The threaded replacements will fit, however, by carefully screwing them in.  Use just enough pressure to get them to seat all the way down, and use a screwdriver that fits the slot (a hollow-ground gunsmith's screwdriver is ideal).  If they are loose, some Loctite may help.  Just don't force them and risk cracking the carb body.
Man, I'm glad you got rid of those apes!  Looking forward to seeing your Dad's bike when it's done!
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
Offline Bellard
« Reply #21 on: June 16, 2011, 04:29:33 AM »
As far as the bike goes I've rebuilt 3 of the 4 carbs waiting on another float. Ill be buying aftermarket airfilters just because I don't wanna deal with the big bugger.
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bankerdanny
« Reply #22 on: June 16, 2011, 08:07:52 AM »
If you mean individual pods, don't do it. You will find thread after thread from 550 owners complaining about how they can't get their bike to run right with them.
The stock airbox is a pain in the ass to be sure, but really you whouldn't need to take the carbs off that often and a once a year or every couple year hassle is a small price to pay for better daily performance.
Offline Bellard
« Reply #23 on: June 16, 2011, 08:13:59 AM »
Ok on that note is there a guide to putting this thing together I got it disassembled
Currently I own
1977 CB750A
1977 CB550K
1971 CB350K3
Offline Bankerdanny
« Reply #24 on: June 16, 2011, 08:39:56 AM »
Someone asked that same question yesterday. Unfortunately no assembly manual.
However the exploded parts diagrams that are found all over should help. I've had mine all apart a couple of times since March, it's actually pretty straight forward to reassemble. The trickiest part are the boots from the airbox to the carbs. They aren't a straight fit, they have to positioned in a specific way to fit onto the carbs correctly.
