Author Topic: 1974 CB750 Shed Find!!  (Read 1845 times)
Offline tango911
« on: June 10, 2011, 07:45:29 PM »
Just sharing another Shed Find. This guy even lives in my town. I was very fortunate to see this on CL right when he posted.
1974 Cb750 Basket Case, but the engine had been painted and polished and the frame freshly painted. Came with some PD carbs as well. Not sure if ill keep them if someone needs some.  Whatever isnt there I should have the parts from my last restore!!  yee haw!  Im currently going to swap out engines in my 72' so i can fix an oil leak then build up another cb750.
chopper bars haha.
How bout that corbin seat!!
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline GammaFlat
Re: 1974 CB750 Shed Find!!
« Reply #1 on: June 10, 2011, 07:48:53 PM »
The oil tank is not from a K4.  It may be a K7/K8 oil tank.
Good luck!
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
« Reply #2 on: June 11, 2011, 04:45:48 AM »
Hmm the fork ears though with the turn signal buzzer are from the earlier bikes. Guess you can date the engine etc with the serial numbers.
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: June 11, 2011, 05:31:25 AM »
Nice find there. I had one of those Corbin seats that was on a dohc 450 I restored, couldn't give the seat away. That is a true king and queen seat 8) 8) ::).   Good luck with the build...Larry
Offline Whizwaz
« Reply #4 on: June 11, 2011, 05:39:05 AM »
That is a great find. Love the king/queen seat too!
Offline tango911
« Reply #5 on: June 11, 2011, 06:02:49 AM »
yes im sure there are parts from different years in that box. The Tank and sides are the Brown color,  the frame is a 74, titled and the engine number if i remember starts with a 230XXXX....  i think.  Ill have to double check it.   Either way should be fun to get another cb750 back on the road. not bad for $400.  Missing a back rim and fender in which I have 2 of each.
« Last Edit: June 11, 2011, 06:05:35 AM by tango911 »
CURRENT STABLE:
K2 (project)
2006 CRF250R
« Reply #6 on: June 11, 2011, 10:40:57 PM »
Tango-From what I have seen you are a very good "picker". You got that nice seat once around the Elkhart area I had my eye on I think  :'(   Keep buying that stuff when you find it around as I do,won't be around forever probably,and sure beats having to go on the internet if you need something  ;)
« Reply #7 on: June 12, 2011, 10:23:01 PM »
Good luck!
Definitely not a K7/K8 oil tank. The late tank is flat across the surface, not curved, the cap area is completely different, and the lines are all routed out the bottom.
Offline tango911
« Reply #8 on: June 13, 2011, 06:22:44 AM »
Thanks,
yes the seat from Breman or close.  I still have it and will hold on to it.  still has the receipt from when the guy buy his cb750 new in 72'.  Its just luck and being the first to call.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline tango911
« Reply #9 on: June 13, 2011, 06:24:35 AM »
Good luck!
thanks for the info.  I didnt look close at the tank,  was pretty sure it works on this 74'.   We'll see when i put it together.   Right now the polished engine is ready to install into my 72.   then ill be able to keep riding this summer while I build up the 74'.
CURRENT STABLE:
K2 (project)
2006 CRF250R
Offline gnarlycharlie4u
  • Far from being an
« Reply #10 on: June 13, 2011, 09:06:15 AM »
Good luck!
I was just about to say the same thing.
The OP's tank looks like a K3/4 tank to me ???
is there a breather vent on the backside at the top? there should be 2 oil lines and 3 tubes coming out of that tank I believe.
Offline canibeyou2
  • oh yes i did
« Reply #11 on: June 13, 2011, 09:58:13 AM »
great find indeed.  that engine looks great.  so there REALLY are deals out there to be had.  good job for helping to restore out faith in the fact that these deals are out there to be found.   cheers
past ownership
73 yamaha xs650
74 moto guzzi interceptor 850
76 harley davidson flh
93 suzuki gsxr 600
91 yamaha fzr 600
1989 kawasaki ninja 250
1987 kawasaki ninja 500
2005 honda vtx 1300
today's garage
2005 yamaha r6
1972 honda cb750
