Author Topic: Electric Tach  (Read 1357 times)
Offline AHawks
Electric Tach
« on: June 11, 2011, 02:26:54 PM »
Ok I need some help. I have a electric car tach and the stock points ignition on a cb550k1. Is there a way to hook this up? I have no problem making an adapter, but none of the adapter schematics online seem to work. Thanks in advance.
Cold as hell,
Black as spades
Re: Electric Tach
« Reply #1 on: June 11, 2011, 03:13:12 PM »
has it got switches on the rear?single cylinder/two stroke might work.
Offline AHawks
Re: Electric Tach
« Reply #2 on: June 11, 2011, 04:09:57 PM »
No just a 4-6-8 switch.
Cold as hell,
Black as spades
Offline CycleRanger
  • No comment about being an
Re: Electric Tach
« Reply #3 on: June 11, 2011, 10:17:35 PM »
Apparently it can work but it must be connected to both coils with some resistors.
There's a lively discussion here:  http://www.venturerider.org/forum/showthread.php?t=29859
Offline AHawks
Re: Electric Tach
« Reply #4 on: June 12, 2011, 06:06:35 AM »
Yeah I found that and it didn't work at all. I made a adapter using another suggestion and it will read up to 2000 rpm but anything above that and the needle drops back to zero.
Cold as hell,
Black as spades
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
Re: Electric Tach
« Reply #5 on: June 12, 2011, 07:57:40 AM »
you would need a pulse width modulator to double the signal from the coil
 because of the negative spark
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline Triffecpa
Re: Electric Tach
« Reply #6 on: June 13, 2011, 06:19:19 PM »
I use a Summit Automotive tach on my CB400F race bike.  I set it to "Four Cylinder" mode.  The bike runs a Dyna S ignition and one of the Dyna diode adapter things to pull a signall off both coils.  Works like a charm.
Don't have specific input on a points system, but it really shouldn't matter.  The points and the Dyna S essentially do the same thing.
Are you sure that the tach works properly?
Tracy
Offline AHawks
Re: Electric Tach
« Reply #7 on: June 13, 2011, 06:52:14 PM »
Yeah tach works great off one coil. Read exactly half. I have tried every combination of diode/resistor adapters I have found online. I just want to make sure I am using the right diodes. I am using 30A surge. Type is 1N4005. Peak Inverse Voltage (PV) is 600.
Cold as hell,
Black as spades
Offline Triffecpa
Re: Electric Tach
« Reply #8 on: June 13, 2011, 07:31:01 PM »
don't have any idea what is inside the black tape on the unit that I got from Dyna.  They sell them for $15 or $20 or something.
