Author Topic: 1976 CB550 Chain Question  (Read 6953 times)
Offline hikerjay
  • 1976 CB550k Owner
« on: June 11, 2011, 06:20:56 PM »
I believe I need to replace my sprockets and chain.  I also believe I need:
17 t and 35 t sprockets and a 100 link non-oem chain.
Does anyone have recommendations on brands; preferably not made in China.
Thank you.
Offline xsmooth69x
Re: 1976 CB550 Chain Question
« Reply #1 on: June 11, 2011, 06:34:37 PM »
JT sprocket front and back 17/37 stock
http://www.bikebandit.com/jt-sprockets-steel-motorcycle-sprocket?mg=957&t=1&td=1
17 - $20.16
37 - $26.99
ek heavy duty 530 100 link chain non o ring
http://www.bikebandit.com/ek-530-sr-heavy-duty-non-sealed-motorcycle-chain
$47.66
and honestly if your teeth on the front and rear are still good i wouldnt replace the sprockets
now some people will chime in and say the chain will wear down faster if you dont use new sprockets..... well we use the standard non o ring chains.... there cheap.... no reason to replace the sprockets if there still good
now if you where using some $150+ x ring moon chain then it will be worth getting fresh sprockets.
just keep the chain lubed up well and you will be fine
1975 CB550 (FINISHED?!?!?)
Offline nayto550
« Reply #2 on: June 11, 2011, 06:38:40 PM »
17 - $20.16
37 - $26.99
$47.66
+1    ditto
1976 CB550F
1976 CB750F - in resurrection process
1988 HD FLHS
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: June 14, 2011, 05:06:20 PM »
Whatever you do, DON'T fit an o'ring chain to your 550. Do a search here for crankcase damage that will result.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Tintop
« Reply #4 on: June 14, 2011, 05:10:45 PM »
Not quite correct Frostyboy.  You can't use a 530 O-ring (to wide, case damage), but you can use a 520.  This does require new 520 sprockets though.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Frostyboy
  • Circa 1951
« Reply #5 on: June 14, 2011, 05:15:11 PM »
<---- stand's corrected. Thanks Tintop  ;)
We haven't met yet.
[CB550F1]
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #6 on: June 14, 2011, 05:22:39 PM »
I've never been able to locate 520 sprockets for the 550.
Any tips there?
Offline tlbranth
« Reply #7 on: June 14, 2011, 05:33:34 PM »
Jimmy, looked to me like you had bigger chain than 530 on your 550, dincha?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #8 on: June 14, 2011, 06:03:04 PM »
I hesitate to suggest this.  But, it is possible use a 530 Oring chain if you offset the front sprocket 1/8 inch.
But, oring chains are heavier and stiffer than standard chains.  Basically, it eats up more HP from whatever your bike makes.
If you are going for a long distance marathon, maybe the trade off is worth it to you.
Just saying...
Offline Tintop
« Reply #9 on: June 14, 2011, 07:03:01 PM »
Any tips there?
The rear I'm using came from SprocketSpecialties (38T alloy), the front is a custom 17T.  Basically a stock CB550 530 remachined for a 520 width chain, although not quite that simple.  You can also use an XL (?, have to check the notes ::)) 16T on the front.  I went 17/38 to get a bit more initial accel., without killing the top end.  This also leaves the option of going 16T front for the stop light wars, without having to mod the chain. ;) :)
Just saying...
You could offset (have to do the rear to match), but that would require a custom sprocket, as moving the stock one out board would cover the fixing groove in the splines.
Like anything else, not all o-ring chains are created equal.  I should explain that I went 520 o-ring for specific reasons. 1st o-ring because my experience is that they run cleaner, and longer when properly maintained.  I plan to continue showing the bike, so reduced cleaning is a priority.  520, because it weigths the same or less than a stock 530, and that's the largest size that will fit a 550.  The chain I'm using was developed for MX racing, and low friction was a priority.  I won't quote the manufactures hype, but this is the link to their tech stuff - http://sidewindersprockets.com/v-series_smart_chain.html
Does it eat HP, guess maybe I should throw a standard 520 in the box TT, for when I take the 550 to the dyno for jetting.  For sure if I was racing it, there would be a standard 520, racing quality chain on it.
Cheers :)
77 CB550 Cafe build
Offline xsmooth69x
« Reply #10 on: June 15, 2011, 04:46:50 AM »
u want to go all nutzzzz on chains check this place out..... aluminum is the thing of the past what hot is titanium sprockets....stronger lighter will never wear down and they can make a custome 530-520 conversion
ii think they might even have kits or a package buy for a custom make. you can even make you sprocket the way you want to look so it could be all cool looking
they even have this uber spiffy moon chain
http://sidewindersprockets.com/chain.html
it has a brain.... i thinks and self lubes itself  :o
Offline xsmooth69x
« Reply #11 on: June 15, 2011, 04:48:11 AM »
^ ow fml! tintop u beat me to it i got lazy and didnt read your whole post.......
im not deleting the other one because that took to much time to type to just let it get erased  ;D
how is that moon chain btw does it really have a brain?
Offline Tintop
« Reply #12 on: June 15, 2011, 02:23:20 PM »
If it does, its not talking.
77 CB550 Cafe build
Offline xsmooth69x
« Reply #13 on: June 15, 2011, 04:18:34 PM »
LOL
but ya in all seriousness is it really a good chain? can you notice a difference from a standard o or x type chain?
im just wondering because when i get the $$$$ i want to do a 520 conversion and i read about that chain a while ago but didnt think anyone on these forums wouldve actually went through the hassle of a conversion and get that exact chain
why didnt you go with those titanium sprockets?
Offline Tintop
« Reply #14 on: June 15, 2011, 05:17:06 PM »
My only observation to date (purely subjective) is that it was very flexible, and moved smoothly.  The wheel did seemed to spin slightly longer, but that could just as easily be all the new parts (wheel bearings/chain/sprockets).
I'm going to be using a dyno to finalize my jetting / tune.  Might pick up a standard 520 to compare. ;)
I already had an alloy 520 rear sprocket, so a sprocket wasn't on the list when I got the chain.  The additional weight savings of Ti for the cost, is hard to justify for the street.
77 CB550 Cafe build
Offline xsmooth69x
« Reply #15 on: June 16, 2011, 03:03:17 PM »
ya if you have extra dyno time and you want to swap chains i would be very very very interested and seeing the difference! i bet no one at that site would think anyone would actually take the time to test their brain chain so they can make all these accusations about it.
ow come one you can justify the Ti sprocket its..... Ti... you could be like "dude look at that..... ya thats right its Ti, do you have a Ti sprocket... nope didnt think so, so i win!" yup thats what i would say  8)
