Author Topic: CB750K3  (Read 10017 times)
Offline SSK
Re: CB750K3
« Reply #50 on: July 27, 2011, 08:00:32 AM »
Exhaust question -
The 4x1 kerker that was on the bike had it's own flange and we're just bolted to the header studs.  Now the new Dunstall head pipes I got call for the original set up and I am not sure what that was,   But after research,  I think i need to remove the studs, add gasket, then the flange and then the new he'd pipes and with the finned spigots tight around them.  If that is the case then i need to buy the gasket, flange and spigots but from Honda it costs $350!!!!!!!ouch...
Any suggestions,  is there another way?
Re: CB750K3
« Reply #51 on: July 27, 2011, 08:13:51 AM »
tHE SET UP YOU NEED MAY BE THIS:
The spigots are thus:
They are held in place by flat top, oval head screws.
The finned part is the clamp.
These should be had for much less than $350 used as everyone took them off to install pipes that didn't need them. I'm like you and had to reinstall them for my pipe.
Re: CB750K3
« Reply #52 on: July 27, 2011, 08:17:39 AM »
There are clamps and spigots on ebay right now for $65 orso.
Offline SSK
Re: CB750K3
« Reply #53 on: July 28, 2011, 01:00:37 AM »
Thanks,  that is exactly what I need.  I'll check on eBay.
