Author Topic: front brake issues help  (Read 706 times)
Offline 73nancy
« on: June 12, 2011, 10:18:32 am »
ok guys having some issues with my front brakes. i have a cb750 k1 that i rebuilt the master cylinder but after install it wouldnt bleed enough to build pressure. could heat it pumping then i started to leak around the lever. so i decided to throw a spare master cylinder off a modern bike which i had used before for a bit. that one pumped up and bleed good. but went for a ride and i only have about the first 1/4 of a pull before it gets so stiff i cant pull it anymore but the bike will barely stop. its almost acting like the caliper is stuck? trying to figure out what i can do untill i rebuild the stock one or buy a new one.
also i know we have a 14mm bore stock but any modern mc you guys would recomend.  i have new braided lines and stock single disc.
k1 cb750 cafe racer (aka Helter Skelter)
k6 cb750 stock daily rider project
k3 cb750 race bike 911 big bore, alum rods, 13:1, race cam other goodies
