Author Topic: Shift lever rubber  (Read 580 times)
Offline apex_seeking
  • Ron Swanson is a
Shift lever rubber
« on: June 12, 2011, 02:22:56 pm »
This is going to sound stupid, but here goes...
I need to remove, without damaging, the shift lever rubber. I have tried a couple of techniques, mostly swearing at it, all to no avail. Anyone have any suggestions? The key here is to salvage it. I could just cut it off but I want to reuse it on another project.
Offline CycleRanger
  • No comment about being an
Re: Shift lever rubber
« Reply #1 on: June 12, 2011, 02:32:15 pm »
try warming it up in some hot water to soften the rubber.
And i think new ones are still available from Honda.
  • Ron Swanson is a
« Reply #2 on: June 12, 2011, 02:59:14 pm »
Thanks. I'll head over to the Honda shop on Tuesday when they open and order a new one.  ;D
Offline Bodi
« Reply #3 on: June 12, 2011, 04:47:17 pm »
Since the lever comes off easily (if still mounted) soak the rubber end in boiling hot water for a few minutes. It will slip right off. Same for installing a new one, makes it dead easy.
