Author Topic: Craigslist 750 Cafe, Version 2 on deck  (Read 70241 times)
Offline Dyrden
« on: June 12, 2011, 07:08:21 PM »
So, I started with a rough running K7.
Untitled by bailey_james62@ymail.com, on Flickr
Took it apart and put stuff in a bucket.
I dont like casting marks.
I do like cool old shocks:
And everyone knows speed holes are cool.
So are shiny parts(not done with these BTW)
Some people think dual carbs are cool(makes it look like a 350 which I like)
But, they dont fit unless...
Youre willing to cut things up, which I am.
Got this in the mail:
Current stuff:
Aluminum Excels out at anodizer getting deep red.
Tank and tail from Benjie
Rearsets TBD
engine degreased but needs more work.
My last build was aluminum but steel throws much more satisfying sparks!!!
« Last Edit: August 03, 2013, 07:19:55 PM by Dyrden »
Offline kap384@telus.net
Re: Craigslist 750 Cafe
« Reply #1 on: June 12, 2011, 10:38:00 PM »
Cool start to your thread!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline CafeDawg
  • Not All Those Who Wander Are Lost!
  • Gone to the Dogs
« Reply #2 on: June 12, 2011, 10:50:49 PM »
Yah I'm intrigued.  Want to see those twin carbs fitted, never seen that.  Is the headlight bucket w/ speedo a Carpy buy?  Been thinking about converting to one like that and get rid of the clutter up front.  If the CB ends up looking as good as the StreetFighter it will be a real fun build to watch.
Respect
CD
Respect & Understanding. U get what U give!
1976 CB550 basket case cafe rebuild
http://forums.sohc4.net/index.php?topic=106235.0
1978 CB750F evolving, daily rider
http://forums.sohc4.net/index.php?topic=89745.0
Offline Dyrden
« Reply #3 on: June 13, 2011, 08:33:09 AM »
Respect
CD
Thx.  Yes, thats one of Carpys.  Ill likely match the paint from the tank to the headlight housing, but need to decide on that first.  Im going to run a simple harness and use an RFID keyless ignition that Ill hide in the headlight housing.  Trying to keep the bars super clean.  I cant wait for the tank and tail so I can actually sit on the bike for the first time and fab up some mounts for rearsets.
Offline immortal
    • 1976 CB750F "Pegasus bike"
« Reply #4 on: June 13, 2011, 09:00:21 AM »
Very nice, love those shocks!
Sometimes...the hard thing and the right thing are the same thing!
1976 CB750F "Pegasus Bike"
http://forums.sohc4.net/index.php?topic=80492.0
Offline CafeDawg
  • Gone to the Dogs
« Reply #5 on: June 13, 2011, 12:51:20 PM »
Sounds good...subscribed!!!
Offline paulh1282
« Reply #6 on: June 14, 2011, 12:50:02 PM »
What 2 carbs are you using to replace the stock 4? I like the idea of that, I have a 650 and just kind of curious. Might like to try that one day, and tell everybody how I got the idea...
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #7 on: June 14, 2011, 01:48:21 PM »
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline Dyrden
« Reply #8 on: June 14, 2011, 03:34:04 PM »
Cycle X has a dual carb set up!
http://www.cyclexchange.net/Carb%20System%20Comp%20Page.htm
That's them. Usually reserved for choppers with backbones since clearing the stock frame is nearly impossible. Nothing a sawsall, grinder and welder can't fix.
Offline immortal
« Reply #9 on: June 16, 2011, 10:16:29 AM »
I'm still drooling over those shocks, are they NOS or did you rebuild them? what model shock are they?..great job!
Offline Dyrden
« Reply #10 on: June 16, 2011, 05:23:42 PM »
Thanks!  Those are early 80s CB900 rear shocks.  And yes, they looked much rougher before I got a hold of them!
« Reply #11 on: June 17, 2011, 04:55:45 AM »
Subscribed
Offline Dyrden
« Reply #12 on: June 19, 2011, 09:58:25 AM »
Just a little progress this week:
Offline Dyrden
« Reply #13 on: June 19, 2011, 06:00:32 PM »
Offline MasterChief750
  • Detonation
« Reply #14 on: June 19, 2011, 06:04:08 PM »
awesome work but seems like a lot of work to make some carbs fit
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Dyrden
« Reply #15 on: June 19, 2011, 07:39:49 PM »
Thanks, yea it is a lot of work but I didnt buy it to take short cuts and I wanted to separate it from the sea of other 750 cafes.
Offline immortal
« Reply #16 on: June 20, 2011, 10:14:52 AM »
Those CB 900 shocks, you did a great job on! Did you rebuild the shocks and if so where did you find the parts? Also isn't the CB900 shock a little taller than what you had before...I'm thinking of switching from my Asia nitrogen shock to these if I can get the height right and replace the bushings etc.  Thanks again its great what you are doing. My build is the Pegasus bike in the project part of the forum.
Offline Dyrden
« Reply #17 on: June 20, 2011, 12:28:17 PM »
Thanks.  It is a little taller which will level out the frame(which I like).  I did buy new bushings and spent a ton of time cleaning/sanding and then masked and primered and painted the bodies.
Offline immortal
« Reply #18 on: June 20, 2011, 01:40:10 PM »
Thanks for the info...great job they look way better than the modern $140.00 Asia nitrogen shocks or the aftermarkets available...although there may be just a little sacrifice in performance. I think I will try eek out a pair to work with.
Offline Dyrden
« Reply #19 on: June 27, 2011, 04:16:39 PM »
Got the rear hub looking good today:
« Reply #20 on: June 28, 2011, 02:53:08 AM »
You did indeed!
Offline Dyrden
« Reply #21 on: June 30, 2011, 05:15:47 PM »
Whats better than velocity stacks?  Nothing....
Offline articblue
« Reply #22 on: July 01, 2011, 12:16:50 PM »
sweet build so far looking forward to progress
Eventually I'll get something that runs, but until then I'll wrench until I make it run.
Project 750
Also, another 'new' project 1975 Honda CB400F.
Offline Dyrden
« Reply #23 on: July 24, 2011, 07:33:17 PM »
Little more progress:
Offline Dyrden
« Reply #24 on: July 24, 2011, 07:35:01 PM »
Tail is out at upholstery, but the tank is nearly done:
