Author Topic: Craigslist 750 Cafe, Version 2 on deck  (Read 56554 times)
Offline tweakin
  • tear down
Re: Craigslist 750 Cafe
« Reply #101 on: November 28, 2011, 06:20:18 AM »
Well done, looking great.
Offline Dyrden
« Reply #102 on: January 04, 2012, 03:29:26 PM »
The holidays slowed me down a bit.  Ive worked on the frame loop and under tail.  Also built part of the rear light.  Its going to be flush mounted inside the rear loop and contoured to fit.  I used a couple of LEDs to get a sense of how bright it will be when done.  I know its not entirely street legal as far as lighting goes but it should do the trick either way.
Untitled by bailey_james62@ymail.com, on Flickr
Im also going to reuse the fender mount which isnt in this photo to support the tail and mount the battery.
Offline Freaky1
« Reply #103 on: January 11, 2012, 09:38:24 AM »
So your gong to make the LED radius around the curved tail section you made?
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline Gruffles
Craigslist 750 Cafe
« Reply #104 on: January 11, 2012, 10:54:00 AM »
Like the direction this one is going, subscribed!
Offline Gixxerusa
« Reply #105 on: January 11, 2012, 12:29:57 PM »
Great build. Can't wait to see it done.  ;) subscribed too
Those without a sense of humor are at the mercy of the rest of us. :)
Offline Dyrden
« Reply #106 on: January 11, 2012, 05:05:07 PM »
Yea Im slotting the tail loop and am going to shape that deep piece of polycarbonate to match the outer profile of the loop.  The poly is 1/2 thick with 16 gauge sheet which ill slot and weld the 1" frame loop to accept.  It should be super clean and hard to detect when the bike is off.  Its a trick ive seen hot rodders use on curved sections of body work.  Basically it will look like its part of the frame.  I had the idea a while ago but got spurred on when I saw Tron recently.  Theres a scene where the bike is speeding away and it had the exact look of this(but not sure how it was executed for the movie).  I also havent seen it done on any of the very many cafe bikes Ive seen.
Offline Freaky1
« Reply #107 on: January 12, 2012, 08:45:25 AM »
It is a very clean look, I've seen it on many rods myself. As for Tron, I'm guessing it was CGI or at least CGI enhanced.
Offline Dyrden
« Reply #108 on: January 15, 2012, 03:55:25 PM »
Did a little more work on the rear sets.  Got some speed holes(height adjustment holes actually) drilled.  Theyll get more smoothing, shaping and polishing before final assembly.
Offline 65Ch3v3LL3
« Reply #109 on: January 16, 2012, 01:17:24 AM »
I see you said you picked the rear sets off of eBay. Do you have a brand name for them? They look pretty good.
Edit - Never mind I found they are Tarozzi rear sets. I might have to look into some of these.
« Last Edit: January 16, 2012, 09:01:07 AM by 65Ch3v3LL3 »
1979 CB650
2011 Harley Road King
2008 Harley V-Rod VRSC DX
2012 Sierra Denali 2500HD
1965 Chevelle Malibu SS
1922 Ford T-Model
Offline neevo
Craigslist 750 Cafe
« Reply #110 on: January 16, 2012, 01:46:50 AM »
Dyrden what tyres you running on those beast rims, any clearance issues?
Offline Vreihenmotor6
« Reply #111 on: January 16, 2012, 08:30:28 AM »
the one in the tron movie is eaier to make than what you're doing
yours could look better though, hopefully the brightness is good
Offline Dyrden
« Reply #112 on: January 16, 2012, 02:50:54 PM »
Those are road riders.  100/90 front on 19 2.5 rim and a 130/80 on an 18 3.5  It has a dresda swing arm and the rear clearance is pretty minimal on the right side.  I prolly have 1 cm between the leading right edge of the tire and the swing arm.
Offline Dyrden
« Reply #113 on: January 16, 2012, 02:56:52 PM »
Yea thats it!  That one looks better from far than up close.  Hopefully mine will look good up close as well.  Its got 36 high output LEDs and Ive tested it outside in the daylight and its pretty bright as the run and very bright as the stop.
Offline Dyrden
« Reply #114 on: January 22, 2012, 01:59:29 PM »
So I got some work done today:
Its extremely bright from behind and pretty bright from side angles.
Offline hapakev
  • Your Standard
« Reply #115 on: January 22, 2012, 04:49:41 PM »
That looks way better than the Tron bike, IMO.  Great project you got there, a lot of very cool ideas!
Smoking Jack
1978 CB750F(ish)
« Reply #116 on: January 24, 2012, 05:55:32 AM »
Great job on the light. What are your plans for the seat?
Craigslist 750 Cafe
« Reply #117 on: January 24, 2012, 06:13:19 AM »
Wow!
Where did the light came from?
Offline HonderCB
« Reply #118 on: January 24, 2012, 07:11:06 AM »
that is so badass dude, nice work.
77' CB750F
81' CB650C - SOLD
Offline dagersh
    • Photos
« Reply #119 on: January 24, 2012, 01:40:14 PM »
Dude......
WOW!
That is breathtaking!  The whole build is BTW...  But that rear light integration to the frame is just awesome!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Cheffish
« Reply #120 on: January 24, 2012, 03:13:30 PM »
Really really good stuff going on here. Will you have turn signals?
Offline cben750f0
« Reply #121 on: January 24, 2012, 05:02:22 PM »
absolutely awesome man, alot of stuff, you have done, just makes me wanna go out a make stuff...haha
brilliant
peace
Offline Dyrden
« Reply #122 on: January 24, 2012, 05:56:58 PM »
Thanks for all the comments guys.  So if I can remember the last few questions:
Plans for the seat? Might do some more stitching, not sure yet.
Whered I get the light?  I made it!  Well, I bought the LED strip and made the rest.
Will the build include signals?  Probably not.  Its going to be barely legal.  In florida we dont need signals.
And the comment on wanting to go out and build stuff... thanks!  I get spurs of motivation and interest when I see what others done.  Sometimes Ill expand on others ideas or take suggestions.  Necessity is the mother of invention.
Offline Freaky1
« Reply #123 on: January 30, 2012, 09:00:02 AM »
Without a doubt, one of my favorite build threads.
Offline AbbyRider
« Reply #124 on: January 30, 2012, 09:34:01 AM »
Nice. I always enjoy a good mix of modern in with classic. Are you doing any white LED's on the front? Or just headlight in the bucket?
'98 VTR1000 Superhawk
'78 CB750F
'77 CB750F (in the works)
'81 KZ650 sitting in pieces in my basement
