Author Topic: Tip: clutch adjustment problems  (Read 1422 times)
« on: June 13, 2011, 07:28:50 PM »
Does your clutch tend to drag even with the proper hand lever free-play and clutch lifter adjustment? I just found the cause of my frustrations. ;D
The pivot hole in the hand-lever was worn, as well as the pivot bolt. The hole was elongated by .030", and the bolt was .014" smaller on the worn side. Even with the cable over-tightened (which would have caused the clutch to slip), there was free-play at the hand lever. I had a spare lever and bolt that were in much better shape, so all is well now. I guess when you grow old with your bike, this type of thing can sneak up on you!
I took a couple of pics; in the second pic, the crescent above the bolt is daylight. :o
Re: Tip: clutch adjustment problems
« Reply #1 on: June 13, 2011, 07:41:26 PM »
Yeah!  ;D
I've actually been there twice with my trusty 750.
Offline crazypj
  • I'm brill, me
« Reply #2 on: June 13, 2011, 10:19:30 PM »
Multiple times with my 550, I turn down bolt and fit a piece of brass tube into lever on most of my bikes now
« Reply #3 on: June 14, 2011, 02:46:17 PM »
bump for Jackhag
