Author Topic: CB500 swingarm - is there supposed to be excess space?  (Read 683 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: June 15, 2011, 02:59:10 PM »
Just put the swingarm on this CB500 and there is about 10mm of extra space between the swingarm and the frame (~5mm on each sides). I know that's not right. From the parts diagram I can't see that I'm missing anything but surely there's a spacer or two that goes there?
Left-to-right there's the nut, washer/cover, frame, swingarm, frame, washer, washer/cover, nut. Am I missing something?
Offline Tintop
Re: CB500 swingarm - is there supposed to be excess space?
« Reply #1 on: June 15, 2011, 03:30:24 PM »
Sounds like you are missing some pieces.  Besides the dust cap/seals, there is a 'plastic' washer, and a felt one on either side.  That would account for the excess clearence
Check this - http://www.cmsnl.com/honda-cb550k2-four-usa_model464/partslist/F++07.html
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline SohRon
« Reply #2 on: June 15, 2011, 05:17:00 PM »
Did you install the two end caps on the arm (#15 in the above list)? I've seen some try to locate these outside the frame, rather than on the ends of the swingarm. As usual, pics would help...
« Last Edit: June 15, 2011, 07:06:01 PM by SohRon »
