Author Topic: CB750F Fork Lowering  (Read 1155 times)
Offline Mandic
« on: June 16, 2011, 04:29:49 PM »
So I've run into an issue.  I bought a spare 78 750F fork to overhaul so I can just swap the one out on my 77F.  I ordered -1 fork tubes from Cycle-X before I stopped and thought. I forgot that the F2/3 have 1" shorter tubes already.  So the -1 tubes I got are the same 23" length as the factory tubes were.  I still want to drop my front end 1".  So rather than sell the ones I accidentally ordered and lose a couple bucks, I'm wondering about doing this method:
http://www.hondachopper.com/garage/shortening_forks/shortening_forks.html
If I am looking to lose 1" how much would I remove?  The article never mentions how much drop he netted but it looks like between 1-2" by the pictures.
Any input?  I have new progressive springs for this build that I would be cutting.  Not exceptionally keen on doing that but if I want to drop I guess it is what I must do.
77 CB750F - Cafe/Daily Rider
Offline Grabcon
Re: CB750F Fork Lowering
« Reply #1 on: June 16, 2011, 07:13:54 PM »
Call Cycle X and see if they will exchange them. I would not hack them off. Worst case have then stick up out of the top clamp by an 1".
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline Mandic
« Reply #2 on: June 16, 2011, 08:02:00 PM »
Trying to avoid that, but it is likely the best bet.  I will have to give Cycle-X a ring tomorrow.  By the time I really had time to think about it today they were closed already.
Offline johnrdupree
« Reply #3 on: June 17, 2011, 06:59:22 AM »
The cutting of the springs isn't what shortens the fork, what does it is the spacer you use (pg. 3, last pic, the bronze bushing).  That bushing prevents the forks from fully extending, hence making them shorter, and the longer the bushing, the more the fork is shortened (what you're doing is pushing the damper piston farther up in the upper tube).  There should also be a small top-out spring where that bushing goes.  It's there so when the fork tops out it doesn't slam the damper piston into the bottom of the upper tube.
When you push the damper piston up in the tube, the main spring will stick out of the top more and that's why you cut them.  You don't have to cut them, you can cram the whole spring down in the tube but it makes the fork stiffer because you're essentially running with a bunch of preload.
I used this method on my 550 fork, but with a small twist.  I used a longer top-out spring instead of a bushing or spacer.  The reason I did this is there are damping holes down near the piston that a bushing would have covered up and I didn't know if that would be a problem.  I found some springs at Ace Hardware that were the same diameter as the top-out spring, but it was about 4" long.  I cut it down to 3" for about a 2" drop (the top-out spring is 1" long).  I cut a corresponding amount off the main spring and called it a day.
There is another way, and if I do it again I might go this route.  Instead of making a new top-out spring, just buy some new ones from Honda.  They still carry them and they cost about $3 each.  Since they are 1" long, adding two more to each fork leg will drop it about 2".  Probably less, though, because they get compressed some when you put the main springs in.  If you don't cut the main spring, the top-out springs get compressed more (making for less drop) because there is more main spring pushing on them.  You can experiment by adding and subtracting springs to get the drop you want.
The springs are part #51412-340-000.  On the fiche for the '78 750F forks they are #5.
Good luck,
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
