Author Topic: A few questions regarding seal replacing and clutch diagnosis. 1974 Cb550  (Read 1461 times)
Offline WarwickE36
I decided to type this as one post instead of multiple ones to keep the main page cleaner, sorry if this isnt protocol, feel free to let me know if it isnt.
Question 1:  I am about to order a gasket and seal kit but want to hear anyone's opinion of the best kit to get...I have done some searching here but there seems to be some discrepancy.
Question 1 leads into question 2: Is it possible to replace the seal behind the drive chain sprocket around the shaft without tearing the motor down and removing the shaft? same goes for the shift lever shaft seal?  I seem to recall someone saying you can (using a screw and pulling on it) ... I have replaced rear wheel bearing seals on solid axle rear ends but always remove the shaft in doing so...
Question 3:  I have some clutch noise (rattle when leaning the bike to the right until fully warmed up) After removing the clutch cover i noticed the basket has about 1/16" of play in and out, do I need new springs, or maybe clutch discs and springs?  My clutch doesnt slip yet, but I would like to replace parts before it does.
Here is a video of the clutch situation...
http://youtu.be/_168VFrd4Xg
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline tommanos
  • 71 CB500
I will try and take number three. I just re-did mt clutch and the book said that if there was more than .1mm play then install a shim between the snap ring and the assembly. Shims come in .1,.3 and .5mm.  I would check to see if the friction plates were worn before trying to hunt down the shims. If you have a way of measuring, the friction plates should be no less than 3. mm. My guess is that if your replaced the friction plates the play would go away.
I am pretty certain that the seal can be replaced without tearing the engine down. Hopefully, someone can report.
BTW, did you order the oil pressure switch?
Regards, Tom
71 CB500
68 CL350
71 CL175
BMW R1100R
Offline WarwickE36
I have a parts list sitting and waiting to pull the trigger on from HDLParts.com I ended up finding the Oil Pressure switch there, the correct page alluded me at first.  So far I have the switch, both seals, and the seal for the kickstart through the clutch housing.  I dont want to order all the seals unless I can do the job without separating the motor cases.
I am a fan of rebuilding necessary wear components... I would consider clutch components wear items.  Normally I dont care about spending a few bucks if the outcome is better.
Thanks for the adivice, hopefully someone can give me some good news on the seals...
2004 SV650s
Offline xsmooth69x
epic video
other than the comment no help here  :(
1975 CB550 (FINISHED?!?!?)
Offline WarwickE36
BUMP for question 2
2004 SV650s
Offline WarwickE36
HELP Clutch diagnosis 1974 Cb550 with VIDEO LINK
« Reply #5 on: July 08, 2011, 06:08:26 AM »
Still looking for ANY advice on the rattle noise my bike makes when leaning it to the right.
It does it from a cold start until its been running about 2 minutes.  If the bike is straight up there is NO noise.  If I lean it to the right it makes a rotational rattle that sounds like something hitting a bell very rapidly.  Obviously something in the clutch area is hitting something when cold, I couldn't find any scaring marks when I had the clutch cover off.  Any help would be greatly appreciated.
You can look back up to my original post to see the VIDEO of the play in the clutch system.
2004 SV650s
