Author Topic: Q's about air compressors, help please.  (Read 1891 times)
Offline Kframe
  • Life is good!
« on: June 18, 2011, 03:17:18 PM »
I think I'm finally going to buy an air compressor, sick of borrowing or making do with other methods.
The project right now is to spray paint a dresser, bookshelf and changing table for the baby's room.
I can spend about $150-200 max on the unit.
I don't know what I don't know, but a couple questions I have are:
1. How big?  Looks like they go from 1gal to 25+.
2. Oil or oil-free?  I have no idea.
3. I've seen some with two hot dog shaped tanks, is that better or worse than one pig shaped one?
I've been procrastinating and doing other stuff to get ready (less than 3 weeks now!) and so I need to make a decision and buy something hopefully tomorrow.
Any advice would be kindly appreciated!
Thanks, -Kris
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline faux fiddy
  • bike in a box
Re: Q's about air compressors, help please.
« Reply #1 on: June 18, 2011, 04:08:04 PM »
Figure out what you want it for. Do you want it to be more or less portable or a fixture at a shop? Do you need it to keep up with air wrenches, nail guns, etc?
You may want to wait until you get what you need for more $.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Kframe
  • Life is good!
« Reply #2 on: June 18, 2011, 04:18:29 PM »
It's gotta have enough oomph for spraying paint, I think the demand is something like 5cfm at 40-50psi.
1986 Honda Helix
Offline TrueSpin
  • Not Really An
  • 1978 750F3
« Reply #3 on: June 18, 2011, 09:38:06 PM »
I've found two things really matter on compressors.
How fast the motor can build pressure, and how long it can hold it.
I installed and used a huge compressor with a 20gal+ tank and a motor so big it required a 240v line. Never missed a beat for painting, airjacks, or any air tools we used (ratchets, impacts, orbitals, etc.) You fire it up in the morning about 5-10 minutes before you need to work, and you'll never be waiting.
At home I use a smaller tank and motor. 3gal~ or so. Good enough for pumping up tires. A bit weak for much else. Used it to spray primer on a car in a pinch, and while it did suffice to get the primer out, downtime for pressurization was a bit much. I wouldn't have used it for a finish coat, but laying primer down is not such an important task, particularly if you're just going to sand/bondo it.
Offline Kframe
  • Life is good!
« Reply #4 on: June 19, 2011, 07:21:04 PM »
As far as paint guns go, do you guys prefer bottom-gun siphon/pressure feed, or top cup gravity HVLP?
I picked up a 20gal compressor at Menards for a buck and a half, it pushes 6cfm at 40psi and about 4.5 at 90.
1986 Honda Helix
Offline faux fiddy
  • bike in a box
« Reply #5 on: June 20, 2011, 01:18:41 AM »
The shop where I tink and dink has one that sounds like that. It did not have a pressure switch for quite a while so you kinda had to unplug it after a job and leave it plugged in for the duration of use and keep an eye on the pressure guage and shut down when it hits 110-120.
All auto now thanks to the bro.
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: June 20, 2011, 09:16:05 AM »
I like the top feed HVLP guns myself.   Watch out - small compressors with small tanks makes painting an adventure.   You'll be able to paint a little at a time, wait for the compressor to catch up, paint more, repeat.....
Offline Skunk Stripe
« Reply #7 on: June 20, 2011, 09:57:37 AM »
I have a husky. 110v 20 some gallon tank with a built on regulator.
I used it for roofing and it worked great. Takes about 10 minutes to fill completely.
I have used it with an air hammer and it worked fine there too.
That said, I prefer the oil style over oil free. They seem to be quieter and last longer. And fill sooner.
Any painting though and you should use a regulator/dryer anyways, for better control.
HVLP require less cfm.
Offline Kong
« Reply #8 on: June 20, 2011, 11:44:52 AM »
The rule with compressors is simple, you can never have one that is big enough.  And sure enough, the one you bought isn't big enough.  Well, it is actually, but just barely so.
Depending on what gun you pick up you may not have enough compressor to run it well.  You definitely do not have enough compressor to shoot a car with a BC/CC job, which would require a full sized gun.  You have plenty there to shoot a motorcyle though, particularly if you pick up a nice little touch up gun to go with it.
On compressors:  In the best of all worlds you would want an oil-less compressor.  Even the slightest oil contamination of  your air when painting will result in fisheyes.  Oilless compressors are hopelessly noisy though, and to tell the truth most of the ones that are sold are pretty poorly made, until you get up to the ones that cost mega-bucks.  Those compressors you see with the double little hotdog looking tanks or the squat little pancake looking tanks, those are made for running construction tools, nailers mostly.  Small Compressors that use an oil bath are common and you often see them hooked up to 15 or 20 gallon tanks.  You also see them atop 50 gallon and larger tanks and of course they get much bigger than that.  If you have enough storage capacity you can shoot anything even with a small capacity compressor.   When you buy one something with about a 30 gallon tank makes it easy to paint bikes and possible to paint cars - small cars..
If you buy an oil bath compressor you will need to put a good filter in your air system and to paint vehicles you need an air system.  Just running a hose off the compressor will work, but it will not work well.  Your air system should be designed such as to capture all the water that condenses in the system, to filter out oil or any other contaminants, and also allow you to dial in the line pressure you prefer.  It does not cost very much to put together a system, just the price of some pipe, some fittings, and a couple of valves.  E-bay is the place to hunt for a good deal on a filter.  You can find suggestions for system design all over the internet.  Just make sure you have at least one tall vertical run with a drain at the bottom and you'll do just fine.  Some guys make theirs out of coper pipe (expensive) and some make it out of PVC (cheap) and some just about anything inbeween (mine is iron water pipe - in the middle price-wise).
For whatever its worth there is a big change going on right now in automotive paints.  Traditional Automotive paints are hell on air quality and the chemicals they emit as they dry are hell on the human body.  Their days are numbered.  More and more laws are being passed to limit the extent to which a person or company can dump trash into the air.  That is a good thing but its going to kill some types of paints.  Manufaturers are switching to water-based paints every day, and its just a matter of time until that is all that is available.  I'm just about done painting so I don't really care, but I have to tell you that of the several jobs I did using water-borne paints a couple of years ago were, to my mind, very disappointing.  Back then I used Auto Air Color paints and it is my understanding that they have completely reformulated their line since.  I'm sure the stuff has got to have got better since I used it, because it couldn't have got any worse.
Paint guns.  If you want to buy a cheap gun look for a siphon feed (paint pot on the bottom of the gun) and rest assured that you are using an out of date antique that very well may have a nozzle on it big enough to shoot mud.  Once again it is a matter of air quality that gives us our modern guns.  High Volume Low Pressure (HVLP) guns are the industry standard now days for automotive refinish.  If you've been looking at the market for guns I'm sure you've noticed by now that they range from cheap to gawd-awful-expensive.  Gawd-awful-expensive guns are worth every single penny they cost, cheap guns generally are not.  There are a few exceptions to this rule though.  Lots of guys rave about the Harbor Freight "Purple Gun" which I understand cost less than $25.  All of my guns and airbrushes are made by Iwata.  They are of the Gawd-awful variety.  Sata guns fall into that same catagory.  Cheap guns go by many names, pretty much anything the Chinese can spell.  There aren't all that many guns in the middle, but you can buy a nice gun from Sharpe or Binks that shouldn't cost you too much.  If you intend to do general automotive type finishing I'd suggest you get something with about a 1.4 mm cap, you'll find it will work with just about anything.  If you plan to shoot cars get a quart (or liter) cup, if you are just going to shoot bikes you can get away with half that.  Do not overlook touch up guns if you are just going to do bikes.  Look at the spec sheet for whatever gun you plan to buy and see what size fan it shoots.  Presume that when you get one in hand you'll only get about 80% of what they advertise when its finally adjusted right, but for bikes try to find one that can shoot at least a 4" fan - standard full size guns shoot a fan about a foot tall.  Once again, as a personal note, the small gun I use is an Iwata LPH-80 (1.2mm) that when adjusted for a very even pattern will shoot a fan 4" tall.  That is a very good size for motorcycle parts.  I also have an Iwata gun that is about 3/4 the size of a full-fledged gun.  My Iwata LPH-300 shoots about a 9" fan when adjusted, compared to a full 12" fan for the LPH-400 (full sized gun).  With the 3/4 sized gun I can clear-coat a fender with one pass of the gun or a tank with 2.  That means I get very even coverage and very fast application.  Now think about this.  If I was shooting a bike with my guns I could use your compressor.  First I'd shoot the fenders, and then I'd stop for a couple of minutes while the compressor kicked on and refilled the tank.  I'd shoot the tank next, then wait another couple of minutes before shooting the oil tank and maybe a helmet or two.  The point being that even a small compressor can do it, you just have to plan the job so you don't run out of air in mid-part.
So from where you are nowhere's what I'd suggest to you.  First go ahead and put a pipe system in where ever it is you plan to paint.  Make sure its got a good vertical run or two, good long slanted pipes, a good water trap, and a pressure regulator/gauge in it somewhere.  Keep your eyes open for an old dead compressor you can pull the air tank off of.  Plumbing a second holding tank into your system (with a water drain) can really add a lot of capability for very little money.  Next start looking for a gun.  I'd definitely buy used if I were you and I'd buy the best gun I could lay my hands on, but if you don't want to spend that kind of money take a good look at some of the guns by Sharpe or take a chance on one of the HF guns if you like.
Oh, here's a hint that is going to save you thousands of dollars and much heartache; always shoot test panels.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Kframe
  • Life is good!
« Reply #9 on: June 20, 2011, 08:11:19 PM »
Thanks for the replies!  Kong, thanks for all that valuable info from experience, helps a lot!
Right now no plans to shoot cars or bikes w/ auto finishes, the current need is something to shoot latex enamel onto furniture that looks halfway decent.
All this is going in a baby room and I know the kid isn't going to care if there is orange peel or not (of course, mama wants perfection, lol).
1986 Honda Helix
Offline MoMo
  • Ride like you're invisible
« Reply #10 on: June 21, 2011, 04:21:20 AM »
You may want to look into the electric HVLP Wagner paint sprayer available at most major hardware stores.  It should fill your immediate need for less than 100..Larry
Offline Kong
« Reply #11 on: June 21, 2011, 11:59:30 AM »
Electric guns are not HVLP, in a very real sense they are no pressure at all.  That said for latex painting they are the only way to go as I understand it.  The thing about automotive paints and the guns used to shoot them is that the paints have a consistency (when reduced) that is similar to water, much different stuff than many wood finishes and most wall paints.  I just have a tendency to think of all painting as automotive type painting.  When you ask a carpenter to envision hitting something he thinks of pounding down a nail, you ask a boxer and he thinks about breaking some opponent's jaw.  I made the mistake of jumping to the conclusion that was what you were interested in.  Sorry 'bout that.  Still, it might be of some value to a guy who is thinking about painting bikes or some such.
1978 Honda CB550K
1977 Honda CB550K
Offline MoMo
« Reply #12 on: June 21, 2011, 06:40:39 PM »
Kong, the Wagner gun I mentioned is advertised as HVLP.  I work at Home Depot and have sold a few to people who used them to paint furniture, most of them are satisfied with the results-and it is only 70 or so. It is the only Wagner sprayer I will recommend as all the rest are crap...Larry
Offline Cuts Crooked
  • Cowboy Biker
« Reply #13 on: June 22, 2011, 12:02:02 PM »
+1 on that!!!! I only a 1.5 horse compressor, but a 30 Gal. tank. I painted my house with it a couple of years ago and never had to wait on it to catch up!
Cuts Crooked
CB 750K8
Old Bikes 'n Old Guns are my first two loves :)
