Author Topic: CB550F Air Cleaner Questions: Element? Plate Seal?  (Read 2116 times)
Offline jorwesflow
  • we're not schizophrenic
« on: June 18, 2011, 09:27:21 PM »
I don't want this to turn into a parts request thread I already started in the classifieds ( http://forums.sohc4.net/index.php?topic=90974.0 ) but I need some help here. i still consider myself a rookie with this '76 CB550F and I am ditching the pods to get as close to stock as possible. I am missing several parts that seem IMPOSSIBLE to find. the element, and the plate seal that sit at the bottom of the air cleaner are nowhere to be found... anywhere. not in my garage, not on the www. i also don't have the spring that holds the main air filter in place in the box. what should i do? are there any homemade ways around these parts if i can't acquire them?
1977 CB550K
Offline xsmooth69x
Re: CB550F Air Cleaner Questions: Element? Plate Seal?
« Reply #1 on: June 19, 2011, 02:01:55 AM »
if no one replies i am in minnesota and im going to sportwheels so i can pick up all those parts.
they have tons of cb550f's so i can pull the parts for you i have a couple things i need too.
since its relatively small a small usps flate rate shipping box should make it cheap.
im not sure what the pricing will be like though there is no set price on stuff. i can txt you a quote and you can throw me a couple dollars for my time  ;)
just a thought
also ebay has this
http://cgi.ebay.com/ebaymotors/1974-honda-cb-550-cb550-four-h276-air-box-parts-_W0QQcmdZViewItemQQhashZitem3a672a0891QQitemZ250838911121QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_722wt_948
not sure if its all the parts though
« Last Edit: June 19, 2011, 02:04:52 AM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline jorwesflow
« Reply #2 on: June 19, 2011, 05:36:14 AM »
sending PM :D
1977 CB550K
Offline jorwesflow
« Reply #3 on: June 22, 2011, 12:11:16 PM »
alright, xsmooth69x did me a huge favor and looked all around sportwheels yard, and found some other stuff i needed, but only found crusty useless plate seals, and foam elements that had turned to powder. Can that foam element be made out of a household material? is the plate seal just a gasket?
1977 CB550K
Offline Ryan66
« Reply #4 on: June 22, 2011, 01:53:04 PM »
Theres uni and other replacement filter on ebay. Id go with an aftermarket as my filter smells like mothballs and is dusty lol
1976 CB550k (cafe project)
Offline jorwesflow
« Reply #5 on: June 22, 2011, 02:02:20 PM »
are you referring to the main filter element? i am talking about the small square thin one that sits at the bottom of the airbox...
1977 CB550K
Offline Ryan66
« Reply #6 on: June 22, 2011, 03:10:02 PM »
I have a 550k and i only have one big half circler shaped filter in mine.
« Reply #7 on: June 22, 2011, 06:06:57 PM »
The element foam needs to be an open cell type that can withstand gas and oil without breakdown.
Filter foam could substitute.  The stock foam was denser/ finer than the Uni foam I have.  About 1/4 inch thick.
The retainer spring could be made up, if you can't find one.  Pic attached:
Offline jorwesflow
« Reply #8 on: June 22, 2011, 09:57:29 PM »
if you look at this diagram (attached), you see what I'm talking about. it's the square foam that goes at the bottom and supposed to filter the breather tube at the bottom I believe. but alas! it's a moot point because although the 5 microfiches I normally use were out of stock of the foam element and the gasket seal, I googled the OE part #'s (who woulda thought?? ???) and the parts turned up at Ron Ayers, where I've bought stuff before (my year/model actually showed out of stock for those parts, but those same part #'s were in stock in other years...not sure how that works ???).
sometimes you gotta just google the part number and see what happens (don't bother googling Bike Bandit's proprietary part numbers btw).
oh and TT, xsmooth69x found the retainer spring piece at that junk jungle in Minnesota and is sending to me. but it looks fairly easy to create on your own anyway.
thanks y'all
« Last Edit: June 22, 2011, 10:00:56 PM by jorwesflow »
1977 CB550K
Offline jmcalalang
« Reply #9 on: June 23, 2011, 01:20:35 PM »
I am looking for the same exact piece, though you're lucky and have the part #19, ive been told that for the actual filter element you can replace it with either a cut to fit scotch pad or sos pad. If you have an extra part 19 just tell me where to send the $ its the last piece i need for the airbox
Offline xsmooth69x
« Reply #10 on: June 23, 2011, 02:06:29 PM »
i can get part #19 those are easy to come by
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #11 on: June 23, 2011, 03:17:25 PM »
I'm still missing part 19 and the spring. I just turned the filter element upside down and taped over the hole. Then used a piece of plastic door shim from Home depot to keep the element in place. Seems to work fine. Unless you're going for museum or collectible quality I don't think that whole crank vent set up does much anyway, as far as runability.
Someday I'll find the right parts but at least I'm out riding the bike (when the weather isn't crappy!)
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
