Author Topic: K8 Jet Needles  (Read 2142 times)
Offline Wisconsin Jeff
K8 Jet Needles
« on: June 20, 2011, 01:37:08 PM »
First off, 1978 CB750K8.
Stock air box, 4-1 CB750F header with Kerker can.  Just installed brandy new air filter and spark plugs.
It seems as though I am running rich at mid-throttle.  I see that the K8 jet needles are not adjustable.  I have read that you can shim them up, but that would make a for a richer condition at half throttle.
Is there another solution, like K7 adjustable needles?  Do I have to replace the needle jets as well?
Is there anything else that would cause a mid-throttle rich condition?
Any input is appreciated.
Re: K8 Jet Needles
« Reply #1 on: June 20, 2011, 07:27:45 PM »
Bump
Offline Coyote13
Re: K8 Jet Needles
« Reply #2 on: June 20, 2011, 08:39:03 PM »
Not 100% on this, but mid throttle should be your pilot jet.  On the PD42's these are press-in, and as far as I know shouldn't need to be changed with the modifications you describe.  Have you done plug chops to confirm the mid-throttle rich condition you're describing?
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Re: K8 Jet Needles
« Reply #3 on: June 20, 2011, 08:44:03 PM »
I didn't do plug chops per se, but the plugs were awful sooty when I took 'em out to check.
Pilot jet/air screw is only going to be effective up to 1/4 throttle.
Offline Coyote13
Re: K8 Jet Needles
« Reply #4 on: June 21, 2011, 06:55:58 AM »
I think you're confusing the Idle Screw (which does control up to about 1/4 throttle) with your pilot jet, which controls 1/4 to I think about 1/2 to 3/4 throttle, where your main jets take over.  I would say do plug chops at each interval so you can say without a doubt what condition your bike is running in on each cylinder at each interval.  It will take some time but you can be sure it will tell you more than I can about your motor's state of tune.  Good luck!
Re: K8 Jet Needles
« Reply #5 on: June 21, 2011, 08:42:47 AM »
Thanks for the advice Coyote, I'll try that.
Re: K8 Jet Needles
« Reply #6 on: June 21, 2011, 08:46:17 AM »
This is the chart I was referencing when refering to the jet needle/needle jet at mid-throttle.
Offline Coyote13
Re: K8 Jet Needles
« Reply #7 on: June 21, 2011, 08:50:55 AM »
There is a chart like that one that is specific for the K8 (no needle clip).  I know I've seen it floating around the forum before, I'll see if I can find it for you.  Same idea, just better for your specific carbs.
Offline Skunk Stripe
Re: K8 Jet Needles
« Reply #8 on: June 21, 2011, 10:11:07 AM »
The fuel screw has a wide range of control, same with the idle jet.
Raising the needle will not affect the low rpm range and starts affecting the mid rpm range some, a bit sooner.
What air filter did you put in? I hope you didn't cheap out on those emgo filters. They apparently are too restrictive compared to the stock honda filter.
Offline dougandarthur
Re: K8 Jet Needles
« Reply #9 on: June 22, 2011, 09:48:32 AM »
Here is another Keihin Chart that is a little different. I wonder which one is closer to correct for 054A Carbs? I am looking for leaner Jet Needles too.
The older I get, the faster I was.
Re: K8 Jet Needles
« Reply #10 on: June 22, 2011, 10:13:11 AM »
I went ahead and cleaned the slow jets again.  They seemed to all be clear.  I also did the clear plastic tube test trick to check my float level.  It looks like the bowls are only about half full on cylinders 1 and 3 and almost all the way full on 2 and 4 (about 3mm below the flange).  I am going to attempt the correction tonight by bending the tangs as well as properly setting the fuel screws.  I'll keep you guys updated on the results.
