Author Topic: How to disable the CB750  (Read 5166 times)
Offline jawntybull
« on: June 21, 2011, 06:56:23 AM »
Based on my recent experience in bringing a '77 model back to life:
Q: how can you disable this robust machine for a week or more, using a screwdriver in less than 10 seconds?
Bandit 1250S, DR650, CB750K
Offline singedebile
Re: How to disable the CB750
« Reply #1 on: June 21, 2011, 07:06:36 AM »
should it be something that is hard to tell upon inspection?
,or i would say something like unscrew the ground
or fiddle with the carbs in some way
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline EMS541A
  • Lights n' Sirens
« Reply #2 on: June 21, 2011, 07:08:20 AM »
I think this might be the first person I've seen trying to STOP a CB750 from running...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: June 21, 2011, 07:13:27 AM »
Oh yeah, I can think of half a dozen ways just off the top of my head, probably dozens if I were to stand next to the bike and think about it. I can do some damage, even without tools!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Operator
  • Someday I will live up to being a
« Reply #4 on: June 21, 2011, 07:21:15 AM »
Twist off the ignition wire....
If ever there was a creator of bastard sons, it is the open road, for she has claimed so many young men yearning for freedom......
1973 CB750 K3
1976 CB400F (Cafe Project)
1979 Yamaha XS400 (Currently up for Sale)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: June 21, 2011, 08:20:08 AM »
Well, I would need a screw driver and a pliers, but I would disconnect the condensers from the points.
« Reply #6 on: June 21, 2011, 08:25:02 AM »
Pop off the sidecover and remove  the fuses.
« Reply #7 on: June 21, 2011, 08:40:01 AM »
Take the battery with you? It makes the bike a 500+ lb. paperweight.  ;D
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: June 21, 2011, 08:57:23 AM »
How can you decide how long it's going to take to repair the damage you caused?  I suppose if you opened up the ignition cover and damaged the advance mechanism beyond repair it could take a week or more to get a replacement, but if the owner has a spare it's a quick fix.
Even if you damage the engine enough that it requires removal and disassembly to repair, it wouldn't take that long if the parts are at hand or available for purchase.
How's this:
Put it in gear, wedge the screwdriver between the terminals on the starter solenoid, and send it off riderless over the edge of a cliff or at least into fast-moving traffic.  The resulting damage would probably take a week or more to repair.
Offline DJ_AX
« Reply #9 on: June 21, 2011, 08:58:11 AM »
just snip a few wires somewhere?
Funny ... something like this was just jokingly brought up in a recent conversation....
A buddy of mine's "best friend" was preparing to sell him his old bike.
My buddy took his classes, got his cy license...  and on the day he was going to pick it up, his "best friend" changed his mind about selling it.
I told my buddy I could show him which screws to turn if he was interested in making it less desirable to his friend.  :o
« Reply #10 on: June 21, 2011, 09:02:00 AM »
1. Use the screwdriver the bridge the hot side of the main fuse contact to frame ground. In about ten seconds the wire harness should smoke/melt, maybe even burst into flames.
Should take about a week or more to effect repairs.
2. You could also insert a screwdriver between the chain links at the top side and leave it there.  It's disabled indefinitely.  If ignored and riding attempted, it'll take a week or more restore.
3. Borrow a small child and place it next to the machine and the screwdriver.  Walk away.
4. disconnect the battery.  If you want stealth too, put the cable back on with a nylon screw and a card board insulator sandwiched.
We have ways.
Offline Spanner 1
« Reply #11 on: June 21, 2011, 09:05:20 AM »
1. Get stopped for speeding, 2. Threaten the cop with your screwdriver for 10 seconds. 3. Get jailed immediately for a week.  :o ;D
I like TT's #3..... might be a winner !
« Last Edit: June 21, 2011, 09:09:14 AM by Spanner 1 »
Offline Irukandji
« Reply #12 on: June 21, 2011, 09:41:37 AM »
Sorry but I have to ask ???
WHY??
750k3
Offline Skunk Stripe
« Reply #13 on: June 21, 2011, 10:13:33 AM »
I am guessing it is his bike and he wants to make sure no one can start it and ride off.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #14 on: June 21, 2011, 10:36:25 AM »
Assuming your goal is theft prevention and you want to bring it back to life after the week is up:
1. remove battery
2. disconnect points &/or coils
3. pocket the fuses
4. empty gas tank & float bowls
5. deflate tires
6. Chain it to a pole
7. remove the drive chain
8. Take the plug caps with you
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #15 on: June 21, 2011, 10:57:27 AM »
That is always possible! ;D
« Reply #16 on: June 21, 2011, 11:37:13 AM »
I've seen this: turn the air screws in until they stop. It's almost impossible to start the bike, if it is in good condition (if the vacuum hoses leak, though, it will still run...).
Offline jawntybull
« Reply #17 on: June 21, 2011, 01:01:49 PM »
WHY??
Wow - I was asking as a bit of a joke but what great replies - this is what happens when you go to sleep in Australia and wake up the next morning to check your posts...
Ok, so my answer is - grab a screwdriver and remove one of the drain plugs from one of the carbies. If you want to totally disable the bike remove all four. The drain screws are special items, and you can't just plug the holes with M6 bolts because the valve seat is a special taper at the end of the screw. Without these screws the carbies spew fuel, and if you plug the holes any other way fuel floods up inside the carbies and runs into the airbox. Either way you're not getting far without setting yourself alight.
My fun question was in response to me being off the road for a week due to the loss of one of these screws. Of course you can always buy a whole float bowl from Honda, or order the screws from a site in the US - either way you're off the road for a week.
I reckon my answer is a bit getter than some of the ones like smoking the wire harness - now that's a bit drastic!
pat english
« Reply #18 on: June 21, 2011, 03:55:51 PM »
this sucks...this is a joke thread.and look at all the responses...i have a REAL question posted up right now..22 views and no responses..IS THIS WHAT THIS FOURUM IS ABOUT!!!...HUH!!???
AHHHHHHHHHH....
Offline WarwickE36
« Reply #19 on: June 21, 2011, 04:02:52 PM »
Threaten him with a screwdriver Pat
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
pat english
« Reply #20 on: June 21, 2011, 04:06:39 PM »
hahahaha....i would never do that ;)
« Reply #21 on: June 21, 2011, 04:08:34 PM »
Put Pat and a small child with screwdriver in the same room.  Lock the room and walk away.
jk
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
« Reply #22 on: June 21, 2011, 04:08:58 PM »
Get him Pat....
ok..ok... let's quit F'n around and go help Pat out. ;)
« Last Edit: June 21, 2011, 04:15:31 PM by oldhondarider »
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
pat english
« Reply #23 on: June 21, 2011, 04:25:16 PM »
Get him Pat....
hahahaha i love the internet..
Offline jawntybull
« Reply #24 on: June 21, 2011, 05:04:41 PM »
I just have this image of this great big tough superbike being held to ransom by this little itty bitty screw... a bit like the big giant of a bloke held down by a twisted grip on his little pinkie...
