Author Topic: 78 honda twinstar won't start  (Read 1264 times)
Offline apex_seeking
  • Ron Swanson is a
« on: June 21, 2011, 11:13:41 AM »
I am in posession of a twinstar 185 that is a friends bike. I have been goofing around trying to get it started but with no luck.
I know for a fact that the battery is toast. Thecracks down the side of it from sitting in the sun are a dead give away. I checked the point and it isn't pitted. I cleaned it up with some alcohol and jumped the ignition (no key). I can get the lights on the dash to light up with each kick but I can't get it fied. I know it has fresh fuel. I have even tried carb cleaner directly into the carbs. Still nothing.
Any ideas? I know I'm missing something simple.
PS I checked the fuse (Its awesome that there is only one!) and it looked ok but I went ahaed and jumped it just to be sure. The wiring looks good as well.
Offline tbpmusic
Re: 78 honda twinstar won't start
« Reply #1 on: June 21, 2011, 03:23:59 PM »
Without a good strong battery, you're not goin' anywhere.
It might be a 6-volter, too.....
Bill Lane
Offline kirkn
« Reply #2 on: June 21, 2011, 03:32:33 PM »
What Bill said...
And yes, the '78 and '79 ARE 6-volts.
  • Ron Swanson is a
« Reply #3 on: June 22, 2011, 02:56:52 PM »
Thanks guys. I had a feeling but I thought kicking it over might be enough. I'll look into the battery and yes, it is a 6volt system.
