Author Topic: About to pull tank for paint job, tips before draining?  (Read 1037 times)
Offline jorwesflow
  • we're not schizophrenic
« on: June 21, 2011, 02:53:35 PM »
I'm having a friend paint my tank, but before i drain it and remove it, what should i put in there (after it's drained) to keep it from flash rusting while he has it for a week?
1977 CB550K
Offline Johnie
Re: About to pull tank for paint job, tips before draining?
« Reply #1 on: June 21, 2011, 03:32:50 PM »
I did 3 tanks...just drain and you should not have a problem with flash rust.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline WarwickE36
« Reply #2 on: June 21, 2011, 03:36:58 PM »
Leave 1/4 of a gallon or so of gas in the tank ...add a splash of marvel mystery oil (slosh it around) then drain....if your really nervous about it
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: June 21, 2011, 09:45:25 PM »
It's only going to be empty for a week.  Don't worry about it.  Flash rust is only an issue when the surface has been stripped clean either mechanically or chemically.  The inside of your tank is already coated with a very thin layer of corrosion and varnish that will keep further rust at bay for much longer than one week.
Think about it this way.  You don't keep your tank completely full all the time do you?  The top portion of the inside of your tank is exposed to air most of the time, but it's still fine.
« Last Edit: June 21, 2011, 09:47:24 PM by Gordon »
Offline jorwesflow
« Reply #4 on: June 22, 2011, 09:26:59 AM »
ok, thanks guys. i've never done it before and i guess it's not as big of a deal as i thought. i just remember cleaning rust out of the tank out last year with muriatic acid, which worked great, but then being able to literally watch the rust form after rinsing. I couldn't get the gas in quick enough. But i take it once the gas is in and everything is coated, everything's fine when you go to drain. thanks again!
1977 CB550K
Offline Vintage Esquire
« Reply #5 on: June 22, 2011, 09:37:31 AM »
My only other thought is that you may want to clean the inside of the tank PRIOR to having it painted.  I went to Home Depot and purchased a gallon of phosphoric acid for about $15.  Slosh it around the inside of your tank for 3 minutes, dump out, and repeat.  All of the rust in your tank will be gone and you won't have to worry about etching or damaging your new paint job later.
Offline gnarlycharlie4u
  • Far from being an
« Reply #6 on: June 22, 2011, 10:38:32 AM »
this will cause flash rusting unless you get the stuff that has a rust inhibitor built in. also if you do this you'll probably have to line the tank to prevent rusting.
Offline cafe400f
« Reply #7 on: June 22, 2011, 10:39:17 AM »
I cleaned mine and sealed it before painting.  Used the KBS kit, which cleans, removes the rust and then permanently coats it.  I figured I might as well seal it and never have to worry about it again, no rust no fuss.
http://www.kbs-coatings.com/cycle-tank-sealer-kit.html
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: June 22, 2011, 10:45:54 AM »
Many here, including me, recommend against lining the inside of the tank unless you're repairing a tank that has significant rust problems.  These tanks, if not mistreated and abused, will last (and have lasted) decades in their raw form.
IMO, lining a tank as a preventative measure is like wearing a cast on your arm to keep from breaking it.  Sure it will work, but it may cause other problems down the line.
Offline Accolay
« Reply #9 on: June 22, 2011, 01:08:53 PM »
If you decide to use anything with acid to clean the tank, just make sure you don't forget to remove the plastic gas strainer with the petcock like, uh....a good friend of mine did...yeah.
1977 CB550F
  • Far from being an
« Reply #10 on: June 22, 2011, 02:39:54 PM »
haha whoops. what about those rubber gromets... how'd they hold up?
