Author Topic: Original Exhaust Modification Possibilities for 550  (Read 929 times)
Offline Vintage Esquire
« on: June 22, 2011, 10:04:47 AM »
My original exhaust is in good shape on the exterior, but I can see that the baffles are a little rusty (I can only guess what they look like inside).  I am thinking about simply cutting the end caps of the pipes and replacing them with new slip on aftermarket end caps.  While it's all apart, I can replace the baffles and baffle material.  Has anyone done this to original pipes OR does anyone have any food for thought?
Offline Grizzly
Re: Original Exhaust Modification Possibilities for 550
« Reply #1 on: June 22, 2011, 10:26:51 AM »
I have a 750K7 with the same style pipes as you. My pipes are from the states and are stamped as such. The pipes are a sealed unit so the baffles are not replaceable as on earlier models. To find out if the baffles have gone give each pipe a sharp tap with your hand, if they are knackered you will hear the baffles rattle. In use the pipes should be real quite, again if the baffles are shot you will hear them rattle, no mistake. If they sound fine just squirt some WD40 etc down the pipe and around the end and that should get rid of the rust.
As the pipes come in one piece, here in the UK at least I don't know of anyone making slip on aftermarket end caps. I know you can get aftermarket 4into1 systems. Also I believe Dave Silver here in the UK are advertising OEM pipes.
Hope this is of some use to you.
The older I get the faster I used to be!!!!
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: June 22, 2011, 10:31:57 AM »
If that's your bike in the picture, those aren't the original pipes.  If the baffles are rusted out and aren't designed to be replaced then you could always buy some new slip-on mufflers.
Offline lone*X
« Reply #3 on: June 22, 2011, 10:43:37 AM »
Good discussion on this just a few weeks back.  Check this thread:  http://forums.sohc4.net/index.php?topic=88931.0
Be sure to watch the video.  You will note that the baffles are not one piece as in the aftermarket and the entire muffler would need to be opened.  As always, your "pipes" may vary.
Opps, Gordon's right, not original pipes in the photo.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline akinz
  • life is a one lap race
« Reply #4 on: June 22, 2011, 11:24:15 AM »
I'm looking for the same info. I have just bought a set of 4 into 4's that are in pretty good shape minus the #3 pipe starting to rust out. Looks from the outside of the pipe that they (baffles) are spot welded multiple times along the muffler.
As for these not being original, could you guys elaborate? The ones I bought look exactly the same and have stamped on them HONDA CB550K.
77 CB550k, Finally completed after 3 long years of a complete teardown and rebuild/modification
77 CB550k, on the backburner to turn into a vintage race bike
79 CBX 1000 an absolute classic I just aquired
2005 Yamaha Raven R6 my street and trackday ride
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: June 22, 2011, 11:32:05 AM »
they look like CB550K 77 - 78 pipes to me. The number stamp will tell all.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: June 22, 2011, 12:20:50 PM »
My apologies. :-[
You're absolutely right.  I was stuck in pre-'77 550K mode.
