Author Topic: Jet size recommendation for 1972 CB750K2  (Read 1639 times)
Offline jwalters
« on: May 03, 2005, 12:53:05 PM »
Hello, my 1972 CB 750K2 is pretty much stock (engine, exahust, carbs) with the exception of my emgo pod filters.  Would my bike benefit from going a size larger on my mains?  Or would I not see much difference since I am still running with the stock exhaust?  The bike runs pretty good right now, but has a bit of a flat spot around 5 - 6 rpm, which made me think it's running a bit lean.  I am curious what others have to say!
Thanks!   :-*
jesse
1997 Suzuki Bandit 1200S
1972 Honda CB 750 K2 "Cafe Racer"
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
Re: Jet size recommendation for 1972 CB750K2
« Reply #1 on: May 03, 2005, 02:09:39 PM »
If you suspect it is runnig lean then find a nice long quiet bit of road, run it at a constant speed for a mile or two, at the rpm you suspect, then cut the engine on the kill switch and pull the clutch at the same time. Cost to a stop, being gentle with the brakes, they are a lot more fierce without the engine running. Pull out the plugs, if they are very pale brown or even white then it's running lean and you needmore fuel in there, if they are dark or sooty then less fuel is indicated. What you want is a nice buff colour. It's known as doing a 'plug chop' ask anyone who rides a tuned two stroke, they generally have this nervous twitch when asked.
In the UK anything over 40 years old only needs insurance and Fuel.
