Author Topic: Oil cooler plumbing verification  (Read 816 times)
Offline Silverback
« on: June 22, 2011, 03:09:19 PM »
Just wanted to verify that this was the correct set-up for this manifold and adapter plate. It appears to be correct based on oil flow diagrams. The lines cross, instead of coming in on each side as I normally see. Not a big deal, but I just need some verification that I have the lines routed properly for oil flow.
« Last Edit: June 22, 2011, 03:39:00 PM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline wrenchmuch
Re: Oil cooler plumbing verification
« Reply #1 on: June 22, 2011, 05:53:54 PM »
It looks right as long as the pic shows the engine side of the adapter plate (pretty sure it does ) .
CB750K1
CB750K4
Offline Bodi
« Reply #2 on: June 22, 2011, 08:05:15 PM »
This is correct.
The filter flows outside to onside, the visible hole on the engine side connects to the IN thermostat port. The OUT port connects to a hole on the filter side, feeding to the outside of the filter. Then cooled and filtered oil flows back through the centre of the attaching bolt and threaded adapter.
The lines cross so that the thermostat is flowing correctly.
Offline Silverback
« Reply #3 on: June 22, 2011, 08:18:27 PM »
Excellent! Thanks for the input!
Chris
78 CB750F racer
78 CB750F stock
01 Aprilia Falco
76 kz400
96 BMW K1100LT
