Author Topic: Sync'd carbs, now bike won't idle  (Read 1174 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: June 23, 2011, 01:32:12 AM »
Let me say first these carbs were screwed with by someone who's idea of rebuilding was replacing perfectly good jets with keyster kits slathered in LITHIUM GREASE???
I rebuilt them correctly and installed them on the bike. It idled but when I hooked up my carbtune the sync was awful, wildly different vacuum in each carb. A buddy held them at 3k while I sync'd them but now the idler screw won't touch the tab on the linkage.
Is there a mechanical explanation in the linkage the PO may have messed with that I didn't catch? Or is my sync job the likely culprit?
1974 CB550
Forever West
Offline WarwickE36
Re: Sync'd carbs, now bike won't idle
« Reply #1 on: June 23, 2011, 06:26:50 AM »
Basically what the last guy said.  You need to make sure you down keep adjusting counterclockwise, if you keep going in that direction you will eventually run out of room. In other words when you finish syncing your master idle screw wont be touching anymore.  Its happened to me before... turn all of the adjusters in a few turns (make sure to do them all equally) and re-sync .. I also dont think 3k is a good place to sync at try 1,500Rpms... once you are close to a good sync idle down to 1k and make sure it will go down this low.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #2 on: June 23, 2011, 06:57:10 AM »
did you do a bench sync first?
that will get all your slides close, and then only small adjustments are needed during the vac sync to make big changes in vacuum.
once you get your bike idling, do your sync at 1500rpms.
as you make your adjustments, the idle will change, adjust it back to 1500 and continue. repeat.
Offline fmctm1sw
« Reply #3 on: June 23, 2011, 06:47:14 PM »
+1.  I always looked through the front and only left a sliver of an opening below the slides on each of them to get started..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
