Author Topic: JB WELD CARB QUESTION  (Read 13938 times)
Offline sportsvan
  • birth, school, work, death
« on: June 23, 2011, 02:03:41 PM »
can i use JBweld inside a carb (one of the float posts has snapped off. ???
78 750f supersport
78 xt 500
80 cb900fa
70 bsa royal star 500
2x 1970 mobylette 49cc mopeds
1972 mini clubman estate !
Offline xsmooth69x
Re: JB WELD CARB QUESTION
« Reply #1 on: June 23, 2011, 02:07:03 PM »
i say no
1975 CB550 (FINISHED?!?!?)
Offline Coyote13
« Reply #2 on: June 23, 2011, 02:07:41 PM »
Probably doable, not recommendable
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline cafe400f
« Reply #3 on: June 23, 2011, 02:33:54 PM »
I would think, theoretically, yes.  I think to myself...what's the worst case scenario here, it doesn't hold and you need to find a new carb.  Its worth a try for the price of JB weld.  JB is supposed to be impervious to gas / solvents.  The trick will be getting it to form correctly, but I think that can be overcome with patience.  You'll need to shape it and such.
Offline fmctm1sw
« Reply #4 on: June 23, 2011, 03:32:01 PM »
I'm pretty sure I had a set of "parts carbs" that I JB welded a post on.  I never used it on a bike and like said above, personally I'd recommend a new carb body over a repair attempt.  But I'd like someone to do it and report on the results...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Coyote13
« Reply #5 on: June 23, 2011, 03:41:22 PM »
You don't think corrosion of the JB Weld could be an issue?  I'm no chemist, but I wouldn't want that anywhere near anything going inside my motor.
« Reply #6 on: June 23, 2011, 03:58:38 PM »
I think the gas will eventually debond the JB weld.
Send your carb to big-jim to have it welded back on.
http://forums.sohc4.net/index.php?topic=18649.msg194947#msg194947
Offline CBGhia
« Reply #7 on: June 23, 2011, 05:09:44 PM »
I had a crack in one of the brass over flow tubes.  I used some jb weld on it 2 or 3 years ago and it has held up just dandy.
Offline haill
« Reply #8 on: June 23, 2011, 05:17:35 PM »
I've got a smackerl at the bottom of my petcock bowl and it's doing just fine.
didn't use it to join parts, but had a pinhole leak and it is not affected by gas,
which it states on the product packaging.
Offline wrenchmuch
« Reply #9 on: June 23, 2011, 05:20:35 PM »
Maybe this thread will help .
http://forums.sohc4.net/index.php?topic=13614.0;nowap
Failing that , I don't see how JB could hurt . If you think you might have it welded don't try and glue it first . The epoxy will contaminate the weld area .
CB750K1
CB750K4
Offline Frankenkit
  • Industrial Strength
« Reply #10 on: June 23, 2011, 07:17:48 PM »
I don't think so. I tried to use JB Weld to seal up a cracked overflow tube and because Oregon has a mandatory 10% ethanol mix, the JB weld turned into a rubbery putty after a couple days in the gas.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline 6adan
« Reply #11 on: June 23, 2011, 09:02:52 PM »
I did just that on a GL1000 carb a couple of years ago and I am still riding the bike with no problems. I did drill a small hole in the post and the body and added a small pin then used the JB Weld. I also put the float pin in to make sure it was straight.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #12 on: June 23, 2011, 09:50:57 PM »
Yep, evil ethanol turns the jb weld into leaky goo.
pat english
« Reply #13 on: June 24, 2011, 03:22:47 AM »
didnt even read youre question...jb weld sucks..bottom line >:(
Offline HondanutRider
« Reply #14 on: June 24, 2011, 05:05:05 AM »
I have done exactly this to a CB350F carb.  The JB Weld held for a while, but it did seem to loosen on the post after several moths.  I was able to get a replacement carb body, so solved my problem that way.  I'd consider JB Weld a temporary solution at best.
Offline Freaky1
« Reply #15 on: June 24, 2011, 05:05:32 AM »
I love JB Weld, can't tell you all the things I've used it on with great success, but I can tell you the one thing it didn't work on, overflow tubes in my carbs. Don't even waste your time.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #16 on: June 24, 2011, 05:24:06 AM »
Lots of different experiences with the stuff it seems. I have it sealing one overflow tube and as a repair on one float post. It's been fine for over a year, and we use 10% gasahol here. The key is to allow the stuff to cure completely, like 24 hours, before exposing it to gasoline. Also, don't use the quick curing version. Use the old original version.
Stu
MCN DTF
bollingball
« Reply #17 on: June 24, 2011, 05:43:06 AM »
+1 chickenman I think it is a lot like paint it is all about the prep. I have used it tanks before they came out with por15 never had a leak. I would think of it as a last resort and back then it was :D
                  Ken
Offline Gregorymoto
  • SOHC Aficionado
« Reply #18 on: June 24, 2011, 06:49:13 AM »
I tried to fix a gas tank leak with JB once and it lasted a week, then it started to brake up the melt the JB. So i would say no
Yep, i have issues with this sort of stuff.
Offline WarwickE36
« Reply #19 on: June 24, 2011, 07:40:43 AM »
JB welded a leaky petcock bowl (PO broke the hex off) it leaked within a week.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Bankerdanny
  • Endeavor to persevere
« Reply #20 on: June 24, 2011, 09:27:54 AM »
I used it on a leaky overflow tube about 6 weeks ago. No problems so far. But there was almost a week lag between the repair and when I had the chance to re-install, so it was well cured. I haven't pulled the bowl to see how it's holding up. I suppose I should dp that just to see what it looks like.
pat english
« Reply #21 on: June 24, 2011, 01:37:32 PM »
its still glue...still sucks.... :P
Offline Frankenkit
« Reply #22 on: June 24, 2011, 04:41:14 PM »
mine had been sitting, curing, for 3-4 days before I used it, so I'm not sure how long it needs to 'set'.
1973 CL350- Lola?
Stuff for sale
Offline cameron
« Reply #23 on: June 24, 2011, 06:47:25 PM »
I did that exact thing about 18 months ago.
So far, so good.
A stated... worst case? It doesnt work, you replace the carb anyway.
1976 CB550F
« Reply #24 on: June 24, 2011, 07:03:38 PM »
OR... you can get the part welded back on without drama or worry about it falling off or other undesirable happenings..
See reply #6.
