Author Topic: JB WELD CARB QUESTION  (Read 13954 times)
Re: JB WELD CARB QUESTION
« Reply #25 on: June 24, 2011, 07:21:29 PM »
A stated... worst case? It doesnt work, you replace the carb anyway.
OR... you can get the part welded back on without drama or worry about it falling off or other undesirable happenings..
See reply #6.
+1 on the welding.
Overflow tubes can be easily soldered. Just make sue they are clean and use flux. No trick to it, it will usually wick right into the crack.
« Reply #26 on: June 24, 2011, 07:27:44 PM »
2+ on big-jim's welding, but the OP is in the UK, and Jim is in Georgia. Two-way shipping might make this too expensive of an option??
Offline CBGhia
« Reply #27 on: June 25, 2011, 08:03:23 AM »
I wonder how many people with bad JB experiences were using the "JB Quick weld" or whatever its called.  That stuff has always given me problems, but the regular JB on my overflow tube is holding tight, even with the 10% ethanol.
Offline cameron
« Reply #28 on: June 25, 2011, 11:17:19 AM »
That is actually awesome.
Next time I have my carbs off I will try and remember.
Or when that bowl starts pouring out gas again :)
I was just reminiscing with the GF about that night. We were coming home and it just started leaving a nice trail of gasoline.
I rode home with the petcock closed until she would sputter.. then I would open it for 15 seconds... close it again.. ride till she sputtered... etc etc all the way across town.
Next time that happens.. I will fedex to Jim!
1976 CB550F
« Reply #29 on: June 25, 2011, 12:48:22 PM »
Probably acting like a wad of gum stuck in the crack. Solder is a quick an very permanent fix.
Offline Freaky1
« Reply #30 on: June 25, 2011, 05:35:05 PM »
I used to use the quick weld when I was trucking, saved time, but if you need it to last (or be powder coated over, learned that yesterday) then the original is the best.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline Gregorymoto
  • SOHC Aficionado
« Reply #31 on: March 10, 2013, 05:16:24 PM »
It should work. I have fixed gas tank leaks with it. If it does not work, have it welded by someone that is a super pro welder. Thats not a easy weld to make if my mind eye seves me right.
Yep, i have issues with this sort of stuff.
