Author Topic: CB550 Normal Compression  (Read 1749 times)
Offline phillip56
« on: June 23, 2011, 05:21:15 PM »
I'm just curious if anyone knows what the normal compression is for CB550. Mine seems to have some problems and I'm only getting 90-125 PSI for compression.
Thanks for the help
bollingball
Re: CB550 Normal Compression
« Reply #1 on: June 23, 2011, 05:30:09 PM »
As long as they are close to each other (10%) I think. Don't worry. What is the lowest and highest reading? Was the engine cold or operating temp? was the throttle and choke wide open?
              Ken
« Reply #2 on: June 23, 2011, 05:31:35 PM »
See the engine FAQ.
« Reply #3 on: June 23, 2011, 11:07:10 PM »
is the engine smokey?does it fume from the breather pipe?90-125 is getting a bit low i think,ill wager broken rings if its fumey.,what other problems does it have?
« Reply #4 on: June 24, 2011, 12:01:35 AM »
Thats too widw a range and 90 is too low
« Reply #5 on: June 24, 2011, 12:52:51 AM »
Has the engine been sitting unused for a while?
