Author Topic: 76 cb750 cafe: Project psychogenic fugue.  (Read 2045 times)
Offline devilinlee
« on: June 23, 2011, 10:55:03 PM »
So I bought this bike almost exactly a year ago. I forgot about it and it mostly collected dust until about a month ago when things aligned well enough for me to make some progress.
My first post is here: http://forums.sohc4.net/index.php?topic=73729.msg818853#msg818853
I ordered a benjie tank and seat 3 weeks ago or so and imagine it'll be here in another week or 2. I got my 836 pistons in the mail, and dropped off the top end today to be bored out, honed, and a valve job done. I had the wheels relaced, the rims powdercoated and new tires put on. I stripped the frame and
Now I'm stuck...
My problem isnt lack of information or resources, quite the opposite. I've spent a good deal of time reading up on some of your projects and man are they impressive. I've read article after article and talked with some local bikers and my head is simply spinning. I'm new as new can be to this, part of my problem is that regardless of how much a thread claims to be for dummies, a certain amount of knowledge is assumed. It took me 5 hours to remove the top end of my engine (partly because I had to take a decent number of beer and smoke breaks ) but also just getting hung up on things many of you take for granted i.e. "turn the crankshaft by hand" ...I searched the forums and the manual and it was never explained, thankfully a buddy came out and told me to take off the cover-ma-bob and turn it counter clockwise with a socket to reach tdc. Somwhere in the process of removing the head I lost a couple of jets due to my ignorance, I didnt know what or where they were! anyway, a number of little things like that have me scared i'm gonna screw something up.
I have a list of things I want (i.e. exhaust, headlight bracket, speedo and tach etc.) and I can kind of figure that stuff out on my own but perhaps some of you faithful readers can help me in a few areas.
this is going to be a daily ride but I also want it to be nice. I want it to be quick and have some grunt on the low-end but I dont need to go crazy with performance parts. I'm fine with spending money when and where I need to but it's not exactly falling out of my backside either.
Do stock carbs negate or marginalize the big-bore kit? If so what are my options?
What can be cut off the frame before I have it pc'd? A po already took off the passenger footpeg-a-ma-jigs.
I was considering having someone rebuild the engine but after going through the above steps (big-bore, new pistons, hone and valve job) is it necessary?
Do I need to worry about the bottom end or does everyone pretty much leave that alone as long as it's getting through all the gears?
Do I need to remove all the internals if I want to paint the engine cases?
how important is it to upgrade the cams?
why is there such a huge discrepancy in rear shock prices? you can find them from 70 dollars to 2 grand, do they make that big of a difference?
Do you consider emulators or progressive springs to be best for daily riding?
I have many more questions but that already seems like too many. If I sound like a jack-ass... it's because I am ;) Really I just need a little direction. Somebody slap me in the face, yell at me to calm down and tell me to focus on x please.
« Last Edit: June 02, 2023, 07:51:54 PM by devilinlee »
Offline devilinlee
Re: 76 cb750 cafe: Project psychogenic fugue.
« Reply #1 on: June 23, 2011, 11:17:48 PM »
These are always nice :)
« Last Edit: June 02, 2023, 07:51:24 PM by devilinlee »
pat english
« Reply #2 on: June 24, 2011, 03:18:02 AM »
pretty cool dude.sucks you took apart a running bike..i woulda traded ya a pile a parts for that runner.. ;)
Offline Elan
    • Vital Motor Parts
« Reply #3 on: June 24, 2011, 11:07:09 AM »
hey dude,
I am doing the same project, but am a bit ahead of you. I bored out to 836 and have the engine back together.
To answer some questions in no particular order...
If you are boring to 836, I would be good to replace the cam chain and rubber that supports it. This does require to split the bottom end open.  Theres only 1 cam, and thats generally more of a performance uppgrade, and not mechanically necessary for an 836 setup. If you do get a new cam, you may want to upgrade the engine studs aith APe engine studs.
In the bottom end, you will want to check the primary chains and see how stretched they are. you can do this without opening the bottom end.
You can leave the internals to paint the engine.  Unless you are powder coating. Many of us use VHT engine paint. One plus of taking out all the guts is VHT reccomends baking the parts in an oven for an hour, but it says you can just "bake it" by running the engine. VHT is more resistant to gas, etc.
pretty sure the cheap ebay chocks are cheap for good reason.
some people cut off behind the rear shock and weld in a "loop" that follows the shape of the seat.
Hope that helps!  look forward to seeing some progress!
76 750k
Offline Sheik Yerbouti
  • Likes the warm feeling but is tired of all the dehydration.
« Reply #4 on: June 24, 2011, 11:46:57 AM »
Nice avatar
Offline devilinlee
« Reply #5 on: June 24, 2011, 06:14:39 PM »
Ditto sheik :)
Thanks Elan, I'll do all of that.
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #6 on: June 24, 2011, 07:07:37 PM »
Can I post here so we can have 3 Tom Waits avatars in a row? (I really don't have any good advice to add)
Welcome.
Quote from: SOHC Digger, RIP
'77 CB750k
« Reply #7 on: June 24, 2011, 07:43:12 PM »
G'Day mate, I'm on a similar journey, only in reverse. I'm restoring a K6 from a bare frame and am missing lots of parts, so let me know if you want to sell me any of your stock parts, (tank, seat, shocks, fenders, handlebars etc) and it'll probably help both of us out. Cheers, Terry. ;D
Offline devilinlee
« Reply #8 on: June 02, 2023, 07:20:47 PM »
Well… it’s been 12? Years.  Figure it’s time for an update 😆. Later that year (2011, maybe it was 2012). I realized I was in over my head.  Having the great and All-knowing Mark Paris (aka Hondaman) Not too far from me, I enlisted his help and this was the result 👇. Been a long time but I thought it needed some love and Mark deserved some recognition.  Very thankful to you and your work and glad to see you’re still hanging around here!
Ryan
« Last Edit: June 02, 2023, 08:32:09 PM by devilinlee »
« Reply #9 on: June 03, 2023, 01:35:10 PM »
Great job. Quality isn't easy, cheap or quick.
Offline dusterdude
« Reply #10 on: June 03, 2023, 02:06:00 PM »
Nice,way to go mark
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline wolf550
« Reply #11 on: June 05, 2023, 01:19:25 PM »
wow! that is great to see a project get finished from 2011!
74' CB550 (Sold)
71' CB500/550 (Sold)
« Reply #12 on: June 05, 2023, 05:01:04 PM »
Wow, I barely recognize it now!
