Author Topic: rear hub bushing...  (Read 957 times)
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
rear hub bushing...
« on: June 26, 2011, 07:49:41 AM »
How remove this 4 bushing...?
« Last Edit: June 26, 2011, 12:59:10 PM by bowswell »
Re: rear hub bushing...
« Reply #1 on: June 26, 2011, 08:41:52 AM »
It is a threaded bearing retainer, needs a bar with pins sticking out or similar tool.
 Search removing wheel bearing retainer, should give you the info.
 Carefully drill out the staked holes (punch marks).
Offline Bowswell
« Reply #2 on: June 26, 2011, 01:00:02 PM »
picture modified
« Reply #3 on: June 26, 2011, 10:25:20 PM »
 Us it a 350 or 450 rear hub with the rubber bushings inside for sprocket mounts ?
Offline Bowswell
« Reply #4 on: June 27, 2011, 04:03:08 AM »
cb350f and cb360-350t is samething.
