Author Topic: wtf is wrong with my starter and motor?.......  (Read 11316 times)
Offline xsmooth69x
« on: June 26, 2011, 08:59:58 PM »
bad cb550 starter?
so im getting my bike all hooked up to run and this is what happened...... ^
i know the starter isnt bad because i took this starter out and then put it into my other motor and it worked fine
the teeth on the starter motor is good
the teeth in my motor where its having problems are fine
bike is in neutral idk what to do.....
« Last Edit: June 26, 2011, 09:05:29 PM by xsmooth69x »
1975 CB550 (FINISHED?!?!?)
Offline xsmooth69x
Re: wtf is wrong with my starter and motor?.......
« Reply #1 on: June 26, 2011, 10:35:26 PM »
 ;D
« Reply #2 on: June 27, 2011, 12:47:06 AM »
the one way sprag clutch inside the gearbox might need to come out.
Offline xsmooth69x
« Reply #3 on: June 27, 2011, 02:05:08 AM »
well i can spin the gear inside my engine and it doesn't sound like the video just when the starter is on....
hope that helps lol
« Reply #4 on: June 27, 2011, 02:15:11 AM »
not a real sprag but a term used,does the gear inside turn both ways,or just one way?
Offline xsmooth69x
« Reply #5 on: June 27, 2011, 11:16:54 AM »
only spins one way
Offline xsmooth69x
« Reply #6 on: June 27, 2011, 11:17:43 AM »
The noise is associated with the one way rollers slipping, however they may well grap fine to the hand feel. What happens is a loading and unloading factor  from compression before and after TDC that makes things AFU.
so is this easy access?
and where is this located like the bottom right hand corner?
Offline xsmooth69x
« Reply #7 on: June 27, 2011, 04:01:29 PM »
anyone have a walk through on this
i went through the really big manual thing and i could really find anything on it about the starter and trouble shooting it
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #8 on: June 27, 2011, 04:18:02 PM »
my '77cb550 starter was making similar noises when cold, worked fine when warmed up.  the starter bench tested fine, another good starter made the same noises.  i was advised that the starter "sprag/clutch" was in need of repair or replacement.  access could only be made by splitting the cases.  i later sold the bike, advising the new owner of the particulars.  the bike was tuned well, and started first kick every time, so he didn't seem to mind.
searching for a dr350se
Offline xsmooth69x
« Reply #9 on: June 27, 2011, 04:53:31 PM »
It's attached to the rotor and the cases don't have to be split for the 750. I see now you are ukered with the 550..
ur an evil man sir   :'(
« Reply #10 on: June 27, 2011, 07:35:11 PM »
It's hard to tell from the audio, but it sounds like the starter solenoid is chattering. Do you have a good, fully charged battery, or are you trying to crank the motor with a shot battery and a battery charger?
Offline xsmooth69x
« Reply #11 on: June 27, 2011, 08:23:51 PM »
battery is fresh i just bought it and did all the steps to turn it into a battery and all that
took a multimeter and everything was good
see the thing is, is that i have 2 cb550 motors. one is the main one and the other is a parts motor.
when i try to crank the engine thats in the video ^ that happens
when i stuck the starting motor on my parts bike and cranked it the bike was perfect i could hear all the cylinders moving and some tappet covers are off and could see them moving and i can feel the air coming out of the exhaust holes
« Reply #12 on: June 27, 2011, 08:37:42 PM »
Try using the solenoid from the parts bike.
Offline xsmooth69x
« Reply #13 on: June 27, 2011, 09:49:50 PM »
no no literally i have the spare engine siting on chair
take out the 2 bolts holding on the starter
move the physical starter on the parts motor put back in the 2 screws
then start.
i dont disconnect anything i literally just move the starter to one to the other. i also take some heavy gauge wire and ground the parts motor that is on the chair to the frame of the bike with the motor that is making the noise
im looking at a blow up view of the internals and all i see is gears.... i dont see anything that moves or anything mentioned above........
then again i have not idea lol
Offline xsmooth69x
« Reply #14 on: June 27, 2011, 09:52:13 PM »
where did you get this diagram i cant find it in the shop manual
tdc is top dead center?
what is AFU?
« Last Edit: June 28, 2011, 12:32:42 AM by xsmooth69x »
Offline the technological J
  • deliciouso!
« Reply #15 on: June 27, 2011, 09:56:02 PM »
use your right leg to start it ;D
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline xsmooth69x
« Reply #16 on: June 27, 2011, 10:14:35 PM »
omg like actually physically start the bike that is crazy talk sir!!
Offline xsmooth69x
« Reply #17 on: June 28, 2011, 12:58:46 AM »
bumpppppppppppppp
« Reply #18 on: June 28, 2011, 01:00:42 AM »
Do you have the starter connected to the battery backwards?
Offline xsmooth69x
« Reply #19 on: June 28, 2011, 01:08:41 AM »
then start.
« Reply #20 on: June 28, 2011, 01:25:34 AM »
the primary shaft can be removed without splitting the cases,a bit of a fiddle but ive done it.
Offline xsmooth69x
« Reply #21 on: June 28, 2011, 10:16:07 AM »
550 link below as the freewheel in the pic above is for  function, same idea different location in the engine.
http://www.cmsnl.com/honda-cb550k1-four-usa_model466/partslist/E++05.html
so what parts am i looking at that could be the culprit?
from what im getting part #46 is what the starter connects too and part #48 is the thing with the 3 ball bearings that could be locked up?
Offline xsmooth69x
« Reply #22 on: June 28, 2011, 10:17:01 AM »
what would taking out the primary shaft do? what do you think is wrong dave500?
Offline Roach
« Reply #23 on: June 28, 2011, 11:31:40 AM »
what about using the other motor? otherwise i would just kick start it to atleast see if the motor you are having the troubles with even fires up
1978 CB550K Cafe Racer
« Reply #24 on: June 28, 2011, 01:41:18 PM »
the primary shaft goes through the middle of that drive clutch,it has to come out if you want to access that one way clutch,have you turned this motor over by hand yet?removed the pan and looked up into that area?it might have more troubles than obvious.
