Author Topic: Cleaning stubborn accelerator pump jets  (Read 10400 times)
Offline jahmic
    • 78 750F
« on: June 27, 2011, 08:40:14 AM »
I recently ran into a snag in cleaning the carbs on my 1978 750F.  I pulled the main and pilot jets, soaked them in carb cleaner, and soaked the carb body in 50/50 simple green with water.
My goal:  clean this set of gummed up carbs without pulling the carbs apart, and without purchasing an ultrasonic cleaner.
Even after a soak followed by blowing carb cleaner, then compressed air through the accelerator pump lines, I still had a problem.  The number 3 jet was completely clogged.  Both check valves were functioning properly in the pump, but I got no squirt of gas on the bike.  On the bench, removing the fuel line on one side of the rail and plugging it with my finger, then blowing compressed air through the other end still didn't clear out the jet...even with 2ml or so of carb cleaner in the line trying to push through the gunk.  Pressure simply built in the line, and I received a nice shot of carb cleaner in my face when I unplugged my finger.  (Safety note...be 'dorky' like me and wear glasses all the time.  They work)
If your accelerator pump jets are this bad...and you don't want to spend cash on an ultrasonic cleaner...hopefully the following info will help:
Supplies
- 3/32" ID gas tubing
- 10 ml syringe
- Simple Green
The gas tubing I picked up at the hardware store, it's essentially the type of fuel line that you would use to replace the rotted one on your mower/chainsaw/etc.  The syringe I used was a standard medical Luer-lock syringe...the type that allows you to screw a needle onto the end.  Granted, I realize that this isn't the most readily available item, but it shouldn't be too difficult to procure from a pharmacy, vet supply store, or even amazon.com.  Luckily I had some laying around since I work with them daily.  Anything in the 10-20ml range should work.
Here's a photo of a "test fit"...as well as the packaging from the fuel lines I picked up.
The kit also included a 1/16" ID tube, but this ended up being too snug over the post, it didn't allow for the opening of the jet to contact the fluid in the line.  The yellow line pictured is the 3/32" ID line.
Conveniently, the other end of the line fits perfectly over the end of the syringe.  Just a side note on the syringe...you will want a Luer-lock type.  The oral dosing syringe will be too large to fit inside the line, and the tapered end will push the line off the tip.  Take about 4" or so of line, and attach that to your syringe.  Pull in about 3ml of air, then add about 2-3ml of simple green.  You want a space of air between the plunger of the syringe and the fluid, as shown here:
Then, placed the tube over the post. I noticed that i had to  push the tubing down into the carb, putting a link in the line. This pulled the tubing away from the face of the post just enough to allow the fluid in the line to get between the tubing and the opening in the jet:
Push down on the syringe, filling the line with fluid, and secure everything here for a few minutes.  I only waited about 15 or so...but had been blasing the jet with carb cleaner all day to no avail.  You may want to let it soak longer...your call.  The important thing though, is to make sure that the line is pushed down so that it kinks below the post.  This pulls the line away from the front of the post, exposing the jet opening to the fluid.
Ok, now that it's soaked, while making sure the kink remains in place, hold the base of the syringe with one hand, and pull back on the plunger with the other.  You should have a good seal, and will notice significant backpressure in the syringe as you pull back.
Once it's pulled back all the way, release the plunger.  It may take a couple attempts to lubricate things inside the syringe, but it should eventually snap back down pretty violently.  Do this a few times, and you should notice the simple green starting to foam in the line and in the syringe.
After several repetitions I noticed bubbles streaming from the post.  On the next pull, there was no backpressure and the line was clear.  Theoretically...this works due to that sudden change in pressure being able to "break up" whatever is gunked up inside your jets.
Feel free to ask questions...and please...if you try this and it works, post up.  So far, I've only proven it to work once.
Happy wrenching!
« Last Edit: June 27, 2011, 10:21:21 AM by jahmic »
Offline lucky
Re: Cleaning stubborn accelerator pump jets
« Reply #1 on: January 12, 2012, 05:04:57 PM »
You are doing it backwards. EDIT>>( Sorry I should have said,"Another way to do it...)Just spray carb cleaner in where the black rubber hose connects to the carb and you should see it spray out of the brass tube in the venturi.
Simple. No syringe needed.
If the check ball  in the bottom of the accelerator pump is gummed up or corroded you will have to replace that bottom plate with the check ball if cleaning will not fix it.
To test fill all the float bowls with fuel and actuate the throttle. You should see all 4 brass tubes in the venturi squirt fuel. Engine off - or on the bench.
There is also a check ball in the top edge of that float bowl.
It usually is ok . It just keeps fuel from draining backwards down into the accelerator pump.
« Last Edit: March 15, 2012, 12:25:32 PM by lucky »
Offline cmonSTART
« Reply #2 on: January 16, 2012, 03:50:05 PM »
Actually, this thread inspired me to try using a syringe to clean my accelerator pumps.  I have my carb bank completely apart so I used a bit of a different method.  I attached the fuel line and syringe to the intake of the pump, where the black rubber hose connects.  Before this, I sprayed a bit of carb cleaner in the hole.  Some air pressure with the syringe and a quick poke in the jet hole with pick and it cleaned right up.  Good stuff.  Thanks for the idea!
1981 GL1100 Interstate
1978 CB750F Project
« Reply #3 on: March 14, 2012, 09:40:02 AM »
This is a nice elegant solution. The back a forth action is like using a plunger to clear a drain.
Offline lucky
« Reply #4 on: March 15, 2012, 12:23:54 PM »
A good post and another good method!
Offline eyepreferoldermotos
« Reply #5 on: May 01, 2012, 03:20:36 PM »
If you have the carb bank off the bike why would one not want to open the bowls and inspect?
I do like your method tho.
I'm a former traveling musician, so in all my music gear i use guitar strings to clean all my moto jet clogging issues. I tried carb cleaner and wore safety glasses.... has more success with an old tooth brush/guitarstring/tiny flat head screw driver. I really like to see light through all my jets and fuel piping.
But I'm a youngster... I'm still doing everything the hard way to learn.
Thanks for the thread. I love to learn anything about motos.
Ride it - Don't let it sit like a museum piece - Pour some fresh fluids in 'er - Kick'er over - Let the wind run over her cam covers - Listen to her purr
« Reply #6 on: May 01, 2012, 03:42:58 PM »
The guitar string works very well. A strand of copper wire is softer and needs less care in using it. You cannot clean everything chemically. Some of the old additives don;t dissolve.
