Author Topic: 2 different petcocks same bike which one?  (Read 895 times)
Offline xsmooth69x
« on: June 27, 2011, 12:58:55 PM »
these 2 petcocks came off 2 different cb550 tanks
which one should i use?
one petcock has 3 outlet or inlet tubes
the other one has 2....
1975 CB550 (FINISHED?!?!?)
Re: 2 different petcocks same bike which one?
« Reply #1 on: June 27, 2011, 01:01:24 PM »
Do your carbs have two inlet fittings or one?
Offline xsmooth69x
« Reply #2 on: June 27, 2011, 04:00:27 PM »
so the red part is the big 1/4 tube that carries the fuel for between carbs 1&2 and then 3&4
the the blue part is another tube that shares fuel? between 1&2 and also 3&4, this is a smaller tube
the there are these 90" things that come off the sides of 2&3 that i have no idea what they do
then obviously the purple tubes coming off the carb bowl that i have no idea where those tubes end up going either.....
« Reply #3 on: June 27, 2011, 04:07:03 PM »
Not 1/4 inch they are 5.5mm. And, that's why stock used a two output fuel selector.
Part of the bowl vent system; 3.3mm tubing.
Bowl vent air source.  3.3mm tubing routes down behind engine in front of swing arm
Offline xsmooth69x
« Reply #4 on: June 27, 2011, 04:56:05 PM »
so other than the fuel lines everything just vents into the atmosphere under the bike?
also i used 1/4 they seem to work and fit great. used zip ties to secure it even more
autoparts store doesn't seem to like MM
so what petcock do i use?
1 has 3 out things and the other has 2 but they both came off of cb550 tanks
« Last Edit: June 27, 2011, 05:01:00 PM by xsmooth69x »
« Reply #5 on: June 27, 2011, 05:20:05 PM »
You MUST use clamps on the 1/4 tubing because the nipples are actually too small for 1/4 tubing.  It's optional with the correct 5mm.
Auto parts store does want to stock two items when people will buy whatever they stock.  It's up to the buyer to find the correct parts.
Lots of people jam square pegs into round holes.
I've no idea what the 3 nipple valve does.  It's not stock on any CB500/550 I've ever seen.  But, as you are doing, people will put whatever parts on the bike they happen to like at the time.
Offline xsmooth69x
« Reply #6 on: June 27, 2011, 07:31:22 PM »
so do you know what the 3 nipple does?
« Reply #7 on: June 27, 2011, 08:45:51 PM »
that 3rd nipple is for vacuum...no vacuum, no fuel flow...kinda like an automatic fuel shut off...except they go bad all the time and are kinda pita...I wouldn't try to use it given a choice
Offline xsmooth69x
« Reply #8 on: June 27, 2011, 09:44:11 PM »
ok i guess ill rebuild the other one and use that....
