Author Topic: That stupid ball bearing at the end of your clutch rod  (Read 1141 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: June 28, 2011, 11:23:01 AM »
OK - this is actually about my KZ but it works the same as a CB500 & 750. At the end of the clutch rod there is a ball bearing. Inside the motor. I think mine is missing as it now shifts weird and the brand new clutch cable I just installed is adjusted almost all the way out just to get it to work at all. It must've happened when I pulled out the rod to clean that area while installing a new chain.
So....
I'm about 95% sure that this is my problem. Is there any way to check to see if it's down inside the hole where the rod goes? Think a magnetized screwdriver would pull it out? I just don't want to shove another one down there only to find out that wasn't the problem and then have an extra one that I can't extract.
Re: That stupid ball bearing at the end of your clutch rod
« Reply #1 on: June 28, 2011, 11:39:01 AM »
It should be in the clutch lifter itself. I usually grease the little buggers in so they can't fall out again...the lifter has a hole that also accepts the rod, the ball goes in the hole first.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: June 28, 2011, 01:32:38 PM »
So put the ball in and "ram" it in musket-style?
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #3 on: June 29, 2011, 05:24:02 PM »
Yep - I had reservations about this because I could swear that ball never fell out on my watch. Probably explains the way it's been adjusted the whole 2.5 years I've owned it - PO lost it. Ha! Well I'm happy to report that I put a ball bearing in the hole and - with a dab of grease on the end - put the rod back in. I had to back the adjuster WAY out to accomodate the new spacing; but after reinstalling the sprocket cover and tightening up the cable I took it aroudn the block and it shifts better than it ever has. Who knew?!? :) Thanks again HM!
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: July 06, 2011, 12:29:19 PM »
So here's a question: if the ball bearing I used was too small, is there a chance it could get moved out of position internally and do some damage? The one I used was an old steering bearing and it seemed to fit pretty well into the hole but may not have been exactly right.
Offline mrrch
« Reply #5 on: July 06, 2011, 12:45:53 PM »
It shouldn't go anywhere, a properly sized one will stay centered though.
my build
