Author Topic: 350f issues  (Read 5173 times)
Offline nk140
Re: 350f issues
« Reply #25 on: June 29, 2011, 08:00:40 AM »
What am I looking for on the boots?
clamps not tight/bad seal/old cracked rubber = air leak
Ok I will take a look at that as well.
Re: 350f issues
« Reply #26 on: June 29, 2011, 08:07:08 AM »
with the bike running, spray WD40 on each of the boots, @ where it connects to the head and carbs. if the rpms change, you've found your leak
Offline nk140
Re: 350f issues
« Reply #27 on: June 30, 2011, 02:43:56 PM »
well I have come to the conclusion that my starting troubles is a carb issue.  The bike will not start unless I leave the fuel on for about 30 minutes or so.  Once started it will run on only 2-3 and no fuel is getting to 1-4 and will die if I take it off full choke.  I will be taking the carbs off the bike tonight unless anyone can think of anything else.
Offline nk140
Re: 350f issues
« Reply #28 on: June 30, 2011, 07:21:01 PM »
well I took the carb bowls off and they all had fuel in them albeit a small amount in the outer carbs.  I will be dismantling the carbs in the next few days.
Offline 333
  • Time for change
Re: 350f issues
« Reply #29 on: June 30, 2011, 08:03:20 PM »
While you're in this far, you might check the flow from the tank(fuel line, screen in the petcock...), and maybe the vent in the gas cap.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline nk140
Re: 350f issues
« Reply #30 on: July 06, 2011, 07:34:36 PM »
I think I found the problem....The main jets and the emulsion tubes were clogged.  What causes the white crystalline build up in the carbs?
Offline hondamatteo
Re: 350f issues
« Reply #31 on: July 06, 2011, 10:48:32 PM »
corrosion of the aluminium? Clean them up really well (may require a dunk of some kind to to get all the corrosion out) and try again.
'74 CB350F
Offline nk140
Re: 350f issues
« Reply #32 on: July 07, 2011, 06:46:06 AM »
I will be cleaning them up really well tonight...I ordered a set of carb rebuild kits as well.  Hopefully I will have this thing running on All four cylinders next week.
Re: 350f issues
« Reply #33 on: July 07, 2011, 08:03:37 AM »
brand makes a big difference here.  if you got Keyster kits, reuse your original jets, needles, and emulsion tubes and just poach the soft parts, as jet sizing and needle taper have been known to be different than the originals, making tuning a b!otch..
Offline nk140
Re: 350f issues
« Reply #34 on: July 07, 2011, 09:17:55 AM »
they are K&L carb kits...which I assume the K stands for Keyster?
