Author Topic: Fork Seal Position  (Read 706 times)
Offline sda619
Fork Seal Position
« on: June 29, 2011, 08:34:23 AM »
Ok theres alot of great info on how to replace them, but i have a simple question.
Which side of the seal is up? There is a thick ring part and a softer part. Im assuming to make it easier/harder to slide in or out. which side goes up? or does it not matter.
I noticed while banging them in that i had one in one direction and the other in another direction.
78 cb750f
1978 CB750F first project ever.
Offline mrbreeze
  • Not your average
Re: Fork Seal Position
« Reply #1 on: June 29, 2011, 08:44:25 AM »
I can't remember if they have a spring around the seal lip on both sides (some seals are like that). The spring side goes to the oil and the flat side goes outside. If there is a spring on both sides....my only suggestion is to look at it very carefully and determine which side has the sealing lip. That should be the oil side.
MEMBER # 257
Offline sda619
« Reply #2 on: June 29, 2011, 11:07:37 AM »
i think both sides had the spring.
i would try both sides but man its hard banging it in and out. fortunately my father in law is a mechanic so he has alot of tools he just doesnt know anything about bikes.
Offline Johnny5
    • CB350F build thread
« Reply #3 on: June 29, 2011, 05:02:56 PM »
One side should be more "solid" looking while the other side should look sorta "hollowed" out. But the solid side is the top.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: June 29, 2011, 05:26:56 PM »
Writing side up.
