Author Topic: Compression readings  (Read 724 times)
Offline longshanks
« on: June 29, 2011, 09:35:04 AM »
I've looked around the forum a bit and I can't find the min/max and average compression readings for a K6. The readings on my bike are 120 across all cylinders. Is this low or below average? I believe the shop manual says around 170psi max. but I'm not sure what model that pertains to or all models??
Thanks,
cb450 K5
Re: Compression readings
« Reply #1 on: June 29, 2011, 09:55:21 AM »
readings from gauge to gauge will differ (too many variables)
be happy with your results  ;D
Offline longshanks
« Reply #2 on: June 29, 2011, 10:14:52 AM »
I've tried multiple gauges and its pretty close. Know the specs?
cb450 K5
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: June 29, 2011, 04:30:06 PM »
The spec I go by is that all cylinders are within 10% of each other.  Since you are spot on the same across the motor, it's time to stop worrying and ride!!
I'm sure there is a spec in the Honda shop manual, but unless you have exactly the same tester as the shop uses, the number will be meaningless.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
