Author Topic: Flasher question, confused.........  (Read 1666 times)
Offline dylboss
« on: June 30, 2011, 07:58:40 AM »
Just picked up a '72 CL350 Scrambler.  Gorgeous condition.  Bought it for a song.  I'm having a strange problem though.  All of the sudden the right blinker stopped flashing consistently.  The light will stay on for a few seconds, blink once, then repeat.  Sometimes it won't blink at all.  The left one works flawlessly.  Are the flasher circuits isolated between left and right?  Am I just up against buying a new flasher?
Thanks.
Current
- 1972 CB750 K2 - Brier Brown Metallic
- 1973 CB750 K3 - Flake Sunrise Orange
- 1974 CB750 K4 - Flake Sunrise Orange
- 1976 CB750 K6 - Candy Antares Red
Previous
- 1978 Honda CB550K
- 1972 Honda CL350 Scrambler
- 1972 Honda CB450
- 1998 Suzuki TL1000R
- 1993 Yamaha FZR 600
Offline Bankerdanny
  • Endeavor to persevere
Re: Flasher question, confused.........
« Reply #1 on: June 30, 2011, 08:17:02 AM »
First, beautiful bike. I would love to own one like that. Second, wrong forum, this is the SOHC4 section. Third, you need to replace the flasher unit.
My 550 did the same thing. I installed a modern electronic flasher that I got from Advance Auto Parts, and problem solved, the signals flash fjust fine.
Offline dylboss
« Reply #2 on: June 30, 2011, 08:22:45 AM »
Ok, that's what I figured.  Yeah, I was wondering if I should post on this forum, but there are so many CB guys on here, I figured someone would chime in, so thanks.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Offline wardenerd
  • '77 550F '81 650C
« Reply #3 on: June 30, 2011, 08:27:43 AM »
if the one is working properly and one is not check the ground before doing anything else.  Great bike
Offline Bankerdanny
« Reply #4 on: June 30, 2011, 08:32:20 AM »
I've never seen a question ignored just because it was the wrong Honda, but there is another board farther down the list for other bikes. Lots of the SOHC4 owners are like you and have twins too.
« Reply #5 on: June 30, 2011, 12:11:15 PM »
if all your others work, then its prob not the flasher relay.
get in there and clean the connections, ground, and bulb receptacle.
Offline tango911
« Reply #6 on: June 30, 2011, 12:21:12 PM »
either way a new flasher is like $3
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline dylboss
« Reply #7 on: June 30, 2011, 12:25:24 PM »
Sorry, I should have been more specific.  Both front and rear on the right side don't work.  Both on the left DO work.
Current
Previous
- 1978 Honda CB550K
- 1972 Honda CB450
Online Don R
« Reply #8 on: July 01, 2011, 10:00:46 PM »
My 750's  left blinker got finiky I tightened up the left front light and it was better for a while then quit again. Then both quit. New flasher all is good.
Offline MoMo
  • Ride like you're invisible
« Reply #9 on: July 02, 2011, 07:10:04 AM »
Flasher is good as one side works.. Check for 12v at the blue wire in the h/l shell.  If not there, you have a bad switch. If 12v is there ,check for 12v at the rear t/s blue wire.  If there, check bulbs.  If good, check sockets and t/s stems and green ground wires for corrosion...Larry
