Author Topic: shaving down the weight on my 77 550F  (Read 1270 times)
Offline psycherhexic
« on: July 06, 2011, 02:04:49 PM »
what are some safe things to remove on one of these?
also.. things that aren't so safe, but doable: discuss!
thanks
Offline Gordon
  • 750K1, 550K2
Re: shaving down the weight on my 77 550F
« Reply #1 on: July 06, 2011, 02:08:20 PM »
Lose the starter motor.
Offline sixthwisconsin
« Reply #2 on: July 06, 2011, 02:45:40 PM »
Fenders, especially the rear. It weighs a ton.
Offline betterthanurs916
« Reply #3 on: July 06, 2011, 02:45:51 PM »
There is definitely a lot to be done and everything has a compromise.  I'll rattle off a quick list of things and put my forseeable downside in parenthesis next to it...
--Remove center stand (makes maintenance more of a pain)
--Remove side stand (you basically have to lean the bike against a wall or have a stationary stand for it anytime you want to stop)
--Remove turn singals (arguably less safe on the road)
--Remove front fender (more junk is going to fly on the bike and in your face)
--Remove rear fender (more junk is going to fly up the tail end of the bike, you'll need to figure out the tail lamp, and it might look a bit odd with the stock seat)
--Remove or replace mirrors with something smaller (good luck finding some that are as effective)
--Remove passenger pegs and cut off mounts (how are you going to cart around the hot babes???)
--Remove chain guard (slinging oil and crap all over the place)
--Remove grab-rail (not easy to tie things down if necessary without it)
--Cut speed holes in evertying (not super easy to do right, not a whole lot of downsides necessairily)
--Remove gauges and associated hardware (you can't tell how hard you're flogging your engine or how fast your lightweight killer is going)
Those are some of the quick and simple things, there are definitely more...but you start getting a little expensive and/or compromising streetability beyond there.
« Last Edit: July 06, 2011, 02:47:38 PM by betterthanurs916 »
1977 CB550F2
« Reply #4 on: July 06, 2011, 03:11:56 PM »
sweet. I was just looking at some specific points on the frame that seemed to be "extra" but I'm positive they are there for strength and probably should be messed with..
« Reply #5 on: July 06, 2011, 03:50:29 PM »
...and my bike would be much faster if I could loose 20 lbs! ;)
Offline coldwave007
« Reply #6 on: July 06, 2011, 04:01:27 PM »
QFT - When I was 205lbs last year, my little 100cc enduro topped out at about 52-54Mph.  I'm now 172 lbs and it tops out 58-60Mph.  Cutting the fat really does help.
Other than that, the post above was pretty sweet about what can be dropped off the machine.  Beyond that you really get into the picky stuff (battery, size of headlamp, etc).
1980 Honda CB650C Custom, 1972 Yamaha LT-2 100
Offline WarwickE36
« Reply #7 on: July 06, 2011, 04:12:36 PM »
Buy an R6, problem solved
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #8 on: July 06, 2011, 05:07:07 PM »
not an option  ;D
so.. about losing the starter motor? uh  :o so then its kickstart only?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9 on: July 06, 2011, 05:11:05 PM »
When she has to stop for the umpteenth time to use the restroom...
Leave without her!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #10 on: July 06, 2011, 06:08:50 PM »
Removing the front fender removes the brace, which is going to destabilise the front some. If you want to remove the front fender, fit a fork brace... That is if you want the bike to handle...You can get cut down fibreglass rear fenders for the 750, i am not too sure about the smaller Honda's but they are definitely lighter. Don't remove the side stand it really doesn't weigh that much, the centre stand weighs a ton and is usually the first thing i remove. Aluminium rims, different discs, there's a ton of ways to remove weight, just make sure if it is structural or suspension that you are weight relieving that everything is just as strong or stronger than original....
« Reply #11 on: July 06, 2011, 06:19:27 PM »
I think the original owner already shaved some off of both fenders... I'm planning on shaving even more, but keeping them there, that way the handling stays.. i think  :P
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: July 06, 2011, 06:24:20 PM »
Well, I suppose if you always parked at the top of a hill you could bump-start it. ;)
Seriously, though, when these bikes are in a halfway decent state of tune, they kick-start very easily (especially the 550), and the starter motor weighs a lot.  Both my 550 and 750 have been kick-start only for about six years, and they're my main means of transportation.  My motivation wasn't weight savings, though.  The electric start stopped working on each one and I never bothered to fix them.  They both still have the starter motors.
Also, by losing the starter motor you have the option of going with a smaller, lighter battery.
Offline david 750f
  • 1976 CB750F
« Reply #13 on: July 07, 2011, 12:05:02 AM »
I have to disagree with Coldwave. Weight has very little effect on top speed. Unless his frontal area (drag) decreased. Weight only has an effect on acceleration. Two up on my CB750F I reach the same top speed, albeit in a much longer distance.
1976 CB 750F
Offline xsmooth69x
« Reply #14 on: July 07, 2011, 02:18:19 AM »
dont they make that thing where you can ditch the battery and the big alternator thing on the opposite side of the points side.
i forgot what it was called..... maybe magneto or something? i remember it reminded me of the evil dude in x-men  :P
1975 CB550 (FINISHED?!?!?)
