Logo merchandise is available at the SOHC/4 Shop
Get a wheel bearing kit.http://www.z1enterprises.com/Wheel-Bearing--Seal-Kit-Front--Honda-CB400-CB750-CB900-CBX-GL1000-2790.aspxEasy to change them. There's several threads here about removing the retaining ring and changing bearings.And if the front bearings are shot you can bet the back ones are too.Any bike that's 35 years old needs new wheel bearings regardless of the mileage, imho.
That bearing kit you linked to says that its for the right side? Also, can that kit be used for the rear as well?
Quote from: longshanks on July 07, 2011, 11:16:30 AMThat bearing kit you linked to says that its for the right side? Also, can that kit be used for the rear as well?The kit is for the front. Both bearings are identical. I think by "right seal" they mean both sides of the bearing are sealed.Here's the link to the kit for the rear: http://www.z1enterprises.com/Wheel-Bearing--Seal-Kit-Rear--Honda-CB650-CB750-2799.aspx
