Author Topic: Using an oil additive with zinc, good or bad idea?  (Read 4705 times)
Offline Trav-i
  • Has finally become an
« on: July 07, 2011, 07:30:58 AM »
I was skimming a Summit catalog last night and I came across this additive from Trick Flow.
http://www.summitracing.com/parts/TFS-94000/
It says that it has some extra anti wear additives that I think might benefit our bikes.  Not only valve train wise but also down in the transmission too.  I thinking that it might be a nice addition to oil changes.
Anyone agree or disagree?  No this is not about oil I'm fine with what I use. ;D
Just thought I'd get some other opinions.
Travis
Forum member #9962
1992 GL1500 Interstate
Offline camelman
  • Man... Myth... Legend
Re: Using an oil additive with zinc, good or bad idea?
« Reply #1 on: July 07, 2011, 07:42:58 AM »
Most engine oils contain zinc in their mixture, although the level of zinc has been decreased since catalytic converters became common on cars.  The zinc was used to help "repair" minor wear in steel parts, and is very effective at that job.  However, it also causes damage to catalytic converters, which is why the concentration of zinc is less now than in 1970.  It is widely believed that the reduced amount of zinc in engine oil has caused premature wear of engine components in pre-catalytic car engines that were designed with the expectation that high levels of zinc would be in the available engine oil.
Most diesel oils have higher levels of zinc due to the higher loads found in diesel valve trains.  I use Mobil Delvac in both my Jetta diesel and my motorcycle.  I do not have any empirical evidence of the benefits of zinc in our motorcycle engines, but I know without a doubt that low zinc oils will allow specific high-load valve train components in the VW diesel engines to wear out VERY quickly.  If you run a low zinc oil in a post 1990 VW diesel engine, then your valve train will wear out within 200,000 miles.  If you run a high zinc oil in a post 1990 VW diesel engine, then you will likely never have to replace your valve train.
There seems to be a threshold at which increasing the amount of zinc in the oil has no further benefit.  I am not sure what that threshold is, but the mobil Delvac I use seems to be good enough for my diesel, so I am using it as is for my motorcycle (it comes with HondaMan's blessing too).  If you are using a low zinc oil, then you might see a benefit to adding the zinc additive... or you could just use mobile Delvac (usually on sale for $9/gallon at my local O'Reilly).
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Skunk Stripe
« Reply #2 on: July 07, 2011, 07:53:36 AM »
From some reading a bit ago, 1200ppm was the max zinc content available even during the 70s high points. It seems that there is little benefit of going higher than that and that more zinc became toxic because the concentration was too high in exhaust.
I doubt in our bikes, anything over 1200 will make any difference.
Offline Lostboy Steve
« Reply #3 on: July 07, 2011, 08:05:55 AM »
What are it's effects on a wet clutch? I would be most worried about that.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: July 07, 2011, 08:27:22 AM »
If the Mobil Delvac comes with Hondaman's blessing then the only thing I would be worried about is what's for lunch.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #5 on: July 07, 2011, 09:42:57 AM »
I have run Rotella T in my bike in the past for the added zinc and saw no problems with the clutch plates for the 10,000 miles or so I used it.
Drew
Offline WarwickE36
« Reply #6 on: July 07, 2011, 10:25:55 AM »
Just switched from Valvoline for wet clutches to Rotella T and like the Rotella better... My bike had been sitting for 5+ years and had some seals leaking...I ordered new seals and they are sitting on my counter at home.  Decided to do an oil change and polish the clutch cover and drive chain cover 2 weeks ago and put in some NEW left over Rotella T (had it sitting around the shop, we use it on our diesel Limo Bus).  The oil leaks have stopped, about 99%.  In just a couple days.  Now this probably means it swelled the seals but the clutch operates great, no pulling or drag.  So far I'm very happy.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
« Reply #7 on: July 07, 2011, 07:17:27 PM »
Isn't that Rotella 40 weight? Maybe I'm thinking of something else.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #8 on: July 08, 2011, 05:22:01 AM »
Both rotella are. The conventional is 15-40 and the synth is 5-40.
