Author Topic: Are all CB throttle tubes the same?  (Read 1305 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: July 09, 2011, 09:25:40 AM »
Got a new RH switch and bought some new grips to go with it. Had an extra throttle tube but one of the holes where the cable hooks to is worn out - oval shaped. So I need to replace. Can I get one off any 70's CB or does it have to be for the 750?
Offline MoMo
  • Ride like you're invisible
Re: Are all CB throttle tubes the same?
« Reply #1 on: July 09, 2011, 09:47:59 AM »
That shape is normal, one notch is round-the other oval.  At least on all Hondas I have...Larry
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: July 09, 2011, 11:01:22 AM »
So which cable goes to which hole? Is the "close" cable the oval one? 'Cause I don't have that one (yet). But on the switch I have, the two threaded holes where the cables attach - one is bigger than the other.
Offline MoMo
« Reply #3 on: July 09, 2011, 06:05:53 PM »
The pull (the top throttle cable) goes to the front hole, other goes to the back.  Only works one way,, Honda liked to make things simple to repair.  At the switch, the front cabe will have a lock nut that does not slide up and down, rear cable nut will move up and down....Larry
