Author Topic: Dyna S ign. - solid copper or suppression plug wires?  (Read 2502 times)
Offline timdhawk
  • 1978 CB750K
« on: July 10, 2011, 07:53:51 PM »
Do I need the suppression plug wires when running the Dyna S ignition, or are the solid copper ones just fine?
thanx
In deeper than I should be...
Offline Kong
Re: Dyna S ign. - solid copper or suppression plug wires?
« Reply #1 on: July 10, 2011, 07:56:39 PM »
What coils are you using?
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
« Reply #2 on: July 10, 2011, 08:33:02 PM »
thanx
The Dyna S doesn't change anything for the spark wires. It just replaces the points.
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« Reply #3 on: July 10, 2011, 10:32:16 PM »
I think he might be asking whether or not the unsuppressed wires will have any negative effect on the
Dyna-S, due to the interference they might produce.  I was a little curious of this myself.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: July 10, 2011, 11:19:08 PM »
Run copper with resistor plug ends.
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: July 11, 2011, 06:45:20 AM »
There is no computing going on in the dyna-s, just on/off switches, so no need for suppressing electromagnetic pulses.
Offline timdhawk
  • 1978 CB750K
« Reply #6 on: July 11, 2011, 07:43:12 AM »
thanks. Im running the Dyna's 3.0 coils. So copper it is...
Offline gnarlycharlie4u
  • Far from being an
« Reply #7 on: July 11, 2011, 10:01:09 AM »
your poor charging system...  :(
« Last Edit: July 11, 2011, 10:02:56 AM by gnarlycharlie4u »
« Reply #8 on: July 11, 2011, 04:33:44 PM »
In that case...you'll want to get some resistance in line with the coils, between the +12 volt supply and the coils. Otherwise, it won't be long before you overheat the Dyna S triggers, and your battery will run lower voltage than it does now. You can make your own from some 1 ohm, 10 watt resistors, or get one of my Resistor Packs (check my website, they are there).
Dyna has always recommended this resistance for use with those 3 ohm coils on these bikes, for several reasons. They just don't make 'em. Since the Dyna S adds about 1.25 amps extra load to the bike all by itself, and the 3 ohm coils add another 1 amp on top of that, you'll be heating up connectors all over the bike, too. the resistors will cool things off and make for a longer-duration spark, in the end. ;)
Offline timdhawk
  • 1978 CB750K
« Reply #9 on: July 13, 2011, 08:17:41 AM »
I have your resistor pack already! = )
Plus I have updated all the electronics and switched everything over to LED's as well...
« Last Edit: July 13, 2011, 08:28:13 AM by timdhawk »
