Author Topic: Speedometer drive oil seal part number.  (Read 4300 times)
Offline CycleRanger
  • No comment about being an
« on: July 10, 2011, 08:05:00 PM »
The oil seal for the speedometer drive isn't listed as a separate part on the fiche.
What you need is a Metric Oil Shaft Seal 34 x 48 x 07 Double Lip.
Offline skamagedon
  • Mad Scientist-Gearhead
  • My other car is a motorcycle
    • Arcade and pinball repair
Re: Speedometer drive oil seal part number.
« Reply #1 on: July 31, 2011, 09:44:40 AM »
thank you
1976 CB550 mutt "Tiger Pain"
(stock carb setup, unifilter, 4-2 baffled)
1976 CB360T "Resto Wifebike...wink wink"
Hot glue is your friend
Offline lucky
« Reply #2 on: August 18, 2011, 12:01:23 PM »
Oil seals and bearing are all available at most bearing supply houses in metric or SAE.
Cost is a lot less than HONDA.
