Author Topic: turbo setup !!!!!It run!!!!!  (Read 1956 times)
Offline Doum
« on: July 11, 2011, 07:47:41 pm »
Someone here any experience with the atp/blake turbo kit?
I know my motor is a 836 low compression,but not sure about the cam.I try to make it run idle and it's impossible,nothing under 2200 rpm.I just ordered a carb kit.Carb is a zenith side draft. Thanks for any help
« Last Edit: September 14, 2011, 08:45:47 pm by Doum »
Offline BLUE71TURBO
Re: turbo setup
« Reply #1 on: July 12, 2011, 08:16:49 pm »
 Doum, I run a  A.T.P. setup.  My carb is a SU carb from Rivera.  Works really well.  I'm really thinking of using a Mikuni HSR series 42mm carb.  It's a way better engineered carburator and way more tunable.
      My turbo bike idles at 1500 rpm's.  I had WEBCAM custom grind a camshaft for me.  You need to find out what cam you have as turbo engines don't like very much duration.  A little more lift than stock is all you need for a good street turbo camshaft.  If the zenith rebuild doesn't help i'd really check the cam and go to a better carburator for sure.  Good luck and keep us posted on what you come up with,  JON G.
Offline Doum
Re: turbo setup
« Reply #2 on: July 12, 2011, 08:22:22 pm »
Thanks a lot for you post.I will wait my carb kit and try it.Do you have picture of the carb you use?
  • Moderator
Re: turbo setup
« Reply #3 on: July 13, 2011, 03:13:42 am »
Offline BLUE71TURBO
Re: turbo setup
« Reply #4 on: July 16, 2011, 06:06:14 pm »
 Thanks SAM .    ;)
Offline Doum
Re: turbo setup
« Reply #5 on: September 06, 2011, 08:38:18 pm »
I work on the turbo bike this weekend after 1 month sitting in the garage.result,idle is impossible.I have check the cam,weber 41-cl. From the shearch I did the 41 grind isnt that much agressive,it's the next one after the stock cam.But just to be sure I install a stock cam in it.Restart,no idle,try 2 different cam,no idle.I can keep it to 2500 if I help all the time with the acceleration pump.....but I want a setup usable on the street.I tried many timing setup...
The car is a zenith,rebuilt
Any suggestion?
Offline buttcan
Re: turbo setup
« Reply #6 on: September 11, 2011, 08:12:32 pm »
I've heard of using a stock Hondamatic cam on turbo applications as they don't have much overlap like the shifter engines.
Inevitability: The realization that no matter how hard you try you'll never be as cool as a bull riding monkey...
Offline Doum
Re: turbo setup
« Reply #7 on: September 14, 2011, 08:33:26 pm »
It run!!!
Problem solved.I worked on it for about 1 month(when I had time to work on it).
Tonight I decide to remove the turbo setup and install a stock carb setup.I removed the headpipe....exhaust pipes....turbo....intake manifold.....WHAT!?!? Someone drill a hole under the manifold with 1/8 npt thread....probably to fit a pressure gauge....but there is already a factory outlet for a gauge.
I put a plug in it,reinstall everything,start,adjust carb and it's done.All this time for a F****** hole!!!! But it run!!!! unbelivable sound,run like a V8,idle fine at 1500 rpm.
Re: turbo setup !!!!!It run!!!!!
« Reply #8 on: September 14, 2011, 09:03:47 pm »
We all love to hear success stories! 8) 8)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #9 on: September 15, 2011, 06:29:59 am »
You never know what "they've" done til you come behind them!Damn interesting and surprising often!! Damn,those BIG air leaks.Glad you got it...now go ride it! Bill
BentON Racing Website
BentON Racing Facebook
Offline Jim F
  • go baby go
« Reply #10 on: September 15, 2011, 12:21:24 pm »
glad you found it before you hurt the motor
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
