Author Topic: LED Turn Signal Indicator Wiring Question  (Read 1720 times)
Offline Owned
    • Finished Product
« on: July 12, 2011, 07:13:32 AM »
I've searched but cannot find what I need.  Help please!
I'm wiring in an LED turn signal indicator into my CB350/400F hybrid bike.  The original diagram has the turn indicator getting power from the Orange and Light Blue wires.  As the LED is polarity sensitive, how am I to wire into the harness?  (Orange and Lt Blue are both essentially positive).
Hope this has a simple solution.  I would prefer not to add a second turn indicator bulb to the dash.
-Brad
'01 Ducati 900ssie
'74 Honda CB350F
http://www.flickr.com/photos/indyrider/sets/72157619944545142/show/
'73 Honda CB350/400F Hybrid
http://s1231.photobucket.com/albums/ee520/indyrider2/?albumview=slideshow
'64 Honda CB160 Soon to be unveiled!
Offline Owned
    • Finished Product
Re: LED Turn Signal Indicator Wiring Question
« Reply #1 on: July 12, 2011, 07:17:51 AM »
Do I need to run a line from the Lt Blue and Orange with a diode in place to the positive line of the LED?  If so, what value do I need?
'01 Ducati 900ssie
'74 Honda CB350F
Offline Cqyqte
« Reply #2 on: July 12, 2011, 07:24:41 AM »
If you add a wiring diagram I can look at it for you and offer a suggestion.
Offline Owned
    • Finished Product
« Reply #3 on: July 12, 2011, 07:32:50 AM »
Stock Configuration:
Right +Signal Lt.Blue-----------------------  (Incandescent Bulb)
Left +Signal Orange---------------------
LED Configuration (?)  Will this work?
Right+Signal Lt.Blue------------diode #1----|
        |  Connect to + LED Lead
Left  +Signal Orange-----------diode #2----|
Green (ground)-----------------------------------  Connect to - LED Lead
« Last Edit: July 12, 2011, 08:33:26 AM by Owned »
'01 Ducati 900ssie
'74 Honda CB350F
Offline rooky
« Reply #4 on: July 13, 2011, 11:54:50 AM »
what i did was to fit blocking diodes to the blue and orange wires then join them together and attach the single wire to the +ve side of the led the other side of the led goes to earth
the blocking diodes only work in one direction so try it first before you solder the connections
rickman honda 900
cb750 k6
triton (most of)
cb750 hardtail chop - mid life crisis project
