Author Topic: Can't find non-resistor plug caps--how do you run DR8EIX iridium resistor plugs?  (Read 40611 times)
Offline Spanner 1
OMG........ this Thread might be over after 170 posts.... because I read it in the manual as 23-26 deg BTDC instead of 23-26 deg. PLUS the already 8 degrees @ idle/F mark........... well, were all experts now on ignitions  LOL....... ::) :o :o......... special thanks to Pinhead....
Offline WarwickE36
The Dyna S does not alter the timing from stock when set to the factory
specifications. If you set the timing in the same place as you do with points
the timing will be EXACTLY the same. The difference here is that with the Dyna
S the timing will be EXACTLY the same ALL of the time. There is no change of
time in dwell or timing as the points wear requiring filing and resetting.
Breaker points ignitions are horrible for maintaining settings and maximum
performance. If you look at the timing instructions on any of the Dyna S
applications we always reference the stock timing marks so the factory timing
is retained, at least as a starting point. We did not design the Dyna S to be
run at a timing value other than stock but it does have that ability based on
what the user requires. I hope this helps.
Thank you,
Scott Valentine
Customer Service
Dynatek
1-800-928-DYNA (3962)
http://www.dynaonline.com
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline Deltarider
performance.
Now, now, now, if someone would say: that's an exaggeration, I would call that an understatement.
CB500K2-ED Excel black
Offline Bob Wessner
  • "Carbs Suck!"
I think we have found a challenger to oil threads.  :)
Offline Skunk Stripe
Its been building in power for months! It pummeled its last competition, pod filters.
Offline Holden
performance.
We need to get TwoTired's opinion on this...
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
I think not, sir. The pods thread was over 500 entries.
http://forums.sohc4.net/index.php?topic=20869.0
No.
Offline Syscrush
  • Sold. :(
What we need is a thread with 1000 posts arguing about which oil, pod, or plug thread was more epic. :)
This one has youth on its side! ;D
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Youth is fleeting.
No.
Offline Holden
Yeah, 185 replies in a little over a week isn't bad.
We've discussed plugs, points, coils, electronic ignitions, and timing...what's next?  Wires?  Not many choices...they just seem to work fine.  Condensers?  How do you check them?  If I had an electronic ignition I wouldn't have to worry about it...
Well you should use resistor wire. The resistance makes the spark duration longer!
How now brown cow! :D
Offline Holden
Resistor wire with resistor caps and resistor plugs...your spark might last until the intake stroke and cause pre-detonation.  Not good for crankshaft timing.
« Last Edit: July 21, 2011, 02:30:44 PM by Holden »
Offline WarwickE36
What I find hilarious is that someone would concur that the quicker trigger of electronic ignition is a bad thing.  I paid hundreds of dollars for Dinan to install software into my BMW that advanced the timing map.  I dont know what the settings are an honestly I don't care.  The only difference being my car has a knock sensor and can retard timing if the gas quality is low.  Dinan did a great job as my car now has noticeable more power at top end.  I am a BIG skeptic on performance upgrades.  I usually never see a cost benefit of most bolt on mods.  I dont think my Dyna S has given me any performance upgrade.  But I also dont think it has been a downgrade in performance either.  It IS however maintenance free.  Thats a fact.  You cannot say the same for points.  The Dyna works. PERIOD. Pamco works PERIOD.  Points work PERIOD.  Difference is you get to toy with your points at every maintenance interval.  My electronic ignition doesnt.  If while setting your points you like to sit back and say "those suckers with the electronic ignitions just dont get it." have the time of your life.  I'll be sipping a beer thinking "I can't believe that guy would rather buy points and condensers for the rest of his life than 1 electronic ignition."
2004 SV650s
performance.
Really?  Why?  Hasn't the whole thread turned into a popular opinion poll?  Hasn't had much to do with reality or physics for quite some time.  And the most emphatic insertions have had major hyperbole and little factual/technical data.  Mostly because, who can really argue if your unsupported opinion is wrong, or the unsupported collective opinion is wrong?  Not all lynchings or witch burnings were justified, even if they WERE popular.
Oh, I like blue better than black or yellow.  Maybe we should start a thread for best primary color?  Will all those that don't wear a red bandanna receive a free drive by?
Yes, I'm being sarcastic. :o  Probably from being bitter, or disillusioned about some forum members.  ;D
All that aside, I think Holden is actually a fact seeker, hoping to find some of that before forming an opinion.  I recognize this as different from the forum at large, who prefer opinion first and then gathering in only those "facts" or widely accepted observations, that support the desired opinion.  (There is yet another faction that says "me too" when the sway of popularity is first established.)
Technically speaking, point systems are stone reliable, primarily because they are based on minerals that have existed for millennia.  There is nothing that doesn't have drawbacks/trade offs.  Yes, if you rub a stone long enough it will wear down.  If you mistreat points, they will give you problems.  If you fire a shotgun at either points or electronic system they will both fail.  Beyond straight mechanical wear, the heating of the contact surfaces during the time the contacts are made and broken.  During these transitional times the contact area is reduced and current flowing through small cross sections generate heat.  Like using too small a wire for the current being carried.  There is also the back EMF from the charged coil to consider.  Considering what they withstand, they do a danged fine job, and history has recorded numerous race champions who used points in the winning machines.  So, when someone demands they are inferior, and can't preform, can you believe them?
There are thousands of airplanes still flying today where point contacts are routinely used along with magnetos.  Typical service intervals for these systems are about 1000 hours at 75% power rating for the entire engine.  But, of course, there are certainly some differences between mag systems and other point systems.
Back to what antagonists want to hear, yes, points wear mechanically, and this does gradually change the spark characteristics.  Fast or slow in time is relative to your own personal tolerance.  The tune up schedule for the SOHC4 is 3000 miles.  When I check the timing, it may (or may not) have drifted off one or two degrees.  If it has, a couple swipes with a point file to make them smooth again, then resetting just the gap brings it right back into proper time.  If such a process is too grievous, beyond your ability, or sneeringly distasteful, then you should spend the money to avoid it.  I find that minor task more attractive than shelling out $100-$300 for "improved" ignition and depriving me of what other things that money can buy for me.  I find that spending money I don't need to, is "horrible".  Investing that money in bonds or retirement funds will make it FAR more valuable and appreciated later in life. (wish I'd learned THAT years ago.)
Properly designed, electronic switches should be more stable for a greater duration of time and use without further adjustment.  It still needs to be checked, though.
Presently, I dispute whether simply swapping points for an electronic switch, makes a gnat's ass worth of difference in and of itself for the machine's "performance" (which has a rather broad definition).  All the "modern" ignitions have changed the ignition triggering device, along with coil, wire, and spark plug changes (particularly gap), to provide an entire ignition system overhaul.  The reasons for each elemental change in the system are often coincident with other device changes in the system.  I.E, High performance coils can make points and even early electronic switch triggers fry.  So, another one is developed to enable the desired coil (or spark plug gap) to be used.  Was the old electronic switch faulty, or simply used outside of the role it was originally intended?  Can the same be said of points?  And are you you using the points outside the role they were intended?
My 2007 VW Passat just had a recall to its "modern" ignition system.  I'm not exactly sure what was replaced (under warranty), but I think it was the coil or coil driver.  Anyway, to pass my next emission test I needed to have that piece of paper saying the work was done in order to pass the test.  I didn't notice ANY change to how the car ran either before or after the work was done.    So, do I accept that modern electronic ignitions last forever without failure?  No.  There isn't a machine made that can't ever break.  Most will recognize that after learning of the Titanic.
Personally I think it is "horrible" to encourage others to spend money they don't need to.  Kinda why I'm on this forum.  Helping people make their bike work well, I feel, is better than telling them to take it to a "professional", or to buy this "thing" or widget, simply because it helps justify what I did, foolishly or not.  I know it's not like what government wants, or trains people to act upon, but I like to make my own informed decisions based on knowledge, rather than what somebody decides for me or tells me to do.
Guess I'm a rebel.
Offline Spanner 1
I suppose I need to make an apology to the general Forum populace for thinking that the stock ignition had a 'built-in' lag of 12 degrees......... but with that info. I was ready to go with any other ignition not working to specs.......
Wow all that typing and all it said was blah blah blah and nothing meets my scientific requirements unless I want it too. ::)
Offline fasturd
 Oily Jeebaz....I cannot believe that I sat here and read all 8 pages of this thread.
I have a 400F with points that rips to redline and starts on the first kick.
I also have a 400F with a dyna system that rips to redline and starts on the first kick...
But thanks for all the information. In the future if I have a usable points plate and a decent condensor I will continue to use points but for every bike I buy (and I buy a lot) that comes with a crusty points plate or a bad condensor you can be sure it will have somebodys electronic ignition installed.
Regardless of how your engine gets its spark I wish you all the best of riding!
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
So are you saying that points can be run for 1000 hours without attention? At an average speed of only 30 MPH, that would be 30,000 miles, yet you are adamant about "3000 mile tuneups"???
I have points that have run over 30,000 miles.  They've been dressed 10 times or less in that period.  They drive the stock coils.
I suppose the statement ...
...didn't fit into your outraged positioning.
The 1000 hrs for an airplane mag with internal points is when the RPM drop at run-up is outside acceptance range.  Best not to run them to total failure, even though there are two of them.  Not many places to park in the sky.  Repairing the mag routinely entails replacing the points while the worn out shaft bearings are replaced and it is good to go for another 1000-ish hours at near full tilt.  My last two mags went at 900 and 950 hrs respectively.  I don't think the mag points have the same current flowing through them that the SOHC4 routinely does.
FYI: Electronic ignition for aircraft is quite rare.  It is hard to beat the mag (and it's points) for reliability and redundancy.  And a lightning strike will still allow the engine to keep running and make power.  Still, some experimental aircraft are using electronic these days.
im for electronic,although in airplanes i would imagine two crank angle sensors etc,if one fails etc?
Offline Deltarider
They are so reliable they had to install 2 mags per engine incase one fails.
That's a general principle in aviation. Do you really mind? The old workhorse 747 has many systems... quadruple.
how come i always get the ugly hostess then delta??explain that!!
Offline Deltarider
Somehow I feel this is a joke, but forgive me Dave, being blond, you have to explain. Do not forget: I'm only here to learn English. Hello Goodbye, Ghow are you, I learnuh English, I learnuh eet from a book, e-ven-tu-al-ly.
Offline Simpson
  • I ain't no
  • Aged to perfection
To be clear your only real issue with electronic ignition is the additional cost?  If it were a 50 dollar kit, would you feel differently?
1970 CB750 K0
1975 CL/CB 360 Mix
