Author Topic: 7" Halogen Lamp Conversion Kit Advice??  (Read 13464 times)
Offline wilson889
« on: July 12, 2011, 11:29:36 AM »
Any body know anything about these?? Or is there a better place to order these? I'm looking for something brighter than the sealed beam that I have currently.
7" Halogen Lamp Conversion Kit   ($33.00)
7” Halogen Lamp unit with 12v 60/55 Bulb (P43T base) and Bulb Dust Boot for North American Market RH side Drive.
Fits: Honda CB750 (1969-78)
Part #: 09-0051
http://www.cb750supply.com/products/5/electrical/40/headlamps-headlamps-brackets-headlamp-parts
1975 Honda CB 750K
Offline Lostboy Steve
Re: 7" Halogen Lamp Conversion Kit Advice??
« Reply #1 on: July 12, 2011, 11:44:29 AM »
H.I.D's with the halogen conversion will blind people. They'll also put less stress on your stator!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: July 12, 2011, 11:46:59 AM »
Be a dear and get a projector unit to put in your housing, don't be a total dick and just slap an HID lamp in there without using an HID-specific projector.
Offline Radam
  • taco racer
« Reply #3 on: July 12, 2011, 12:02:27 PM »
I have the $37 one in my bike and I love it. I don't ever use the hi beam unless I'm outside of town after dark. I haven't had any problem with my charging system, but I changed it not long before I got the new headlamp. It's an easy swap if that's what you want to know. It's brighter and cheaper than stock too. I guess only time will tell if screws up my stator.
Offline wilson889
« Reply #4 on: July 12, 2011, 12:28:51 PM »
I apologize for my ignorance, I am pretty new to this. Is there any easy ways of going about the HID route, or would the Halogen(H4)s be the way to go? Also whats better for the charging system, less draw etc..  I would love to learn more.
Thanks
Kevin
1975 Honda CB 750K
« Reply #5 on: July 12, 2011, 12:49:48 PM »
...i like being a dick sometimes don't we all? Anyway on a serious note whats your idea for a projector in the housing? Also, I'll have you know that i only do hid's in the 5000k range no blue or purple.  That makes me less of a dick. Anyway hid's run at way lower amps and watts for more output than a halogen. You know how when you put on a blinker you can see the headlight slightly flicker? Well hid's shouldn't do that.
« Last Edit: July 12, 2011, 12:52:48 PM by twistedengineering »
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline wilson889
« Reply #6 on: July 12, 2011, 12:58:53 PM »
What's more cost effective as well?  any kits with housing available or should a specific housing be bought. ;)
oh and I don't have to worry about blinkers.. they dont work,  lol
1975 Honda CB 750K
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #7 on: July 12, 2011, 02:25:08 PM »
there's nothing wrong with an HID in these conversion housings (non-projector) as long as the cutoff pattern is roughly controlled.  you can accomplish this using shims against the base of the housing on the outside against the bulb.  there's a thread on here about running HID's, and the cutoff patterns were actually impressive for using cheap parts like this!
i'm going to run a DDM 5000k 55w HID on my bike.  i'll spend the time to align it properly for sure!
Offline wilson889
« Reply #8 on: July 12, 2011, 03:15:59 PM »
What's the difference in housings? Ie projector/non projector? And will it make a difference if I just go with the halogen bulbs?
1975 Honda CB 750K
Offline socalenduro
« Reply #9 on: July 12, 2011, 04:03:19 PM »
those items he referenced are not HID correct?
just a halogen upgrade...
Online scottly
« Reply #10 on: July 12, 2011, 08:03:31 PM »
I'm happy with the halogen conversion I did on my bike. As long as the reflector/lens are good quality, like made by Bosch, that sounds like a good deal.
Offline eideteker
« Reply #11 on: July 12, 2011, 10:35:25 PM »
A projector has a lens and cutoff shield that direct the higher output light to reduce glare.  A reflector housing ("non-projector") is like a sealed beam light, the concave rear of the lamp is reflective and that's all the direction the light has - roughly forward, lots of potential for glare, no lens to focus the light.  This is OK for halogen bulbs and sealed beam lamps since the output isn't as high as an HID.
When you have an import vehicle behind you and you hear the fart-can exhaust and can't see through the blazing glare of his bright blue headlights, it's most likely because he is running HIDs in his stock-type reflector housing lamps.
« Last Edit: July 12, 2011, 10:37:57 PM by eideteker »
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline xsmooth69x
« Reply #12 on: July 13, 2011, 01:35:11 AM »
oops thats me right there 6500k blue hid in h4 conversion  ;D
i even used the 20 fleabay 7" headlight with the halo in it hahahahahaha
1975 CB550 (FINISHED?!?!?)
Offline Bodi
« Reply #13 on: July 13, 2011, 04:28:55 AM »
An H4 lamp is not designed for a HID lamp. The H4 bulb has an integral shield to limit glare on low beam. There is no "legal" HID conversion made for H4 lamps and never will be: the light pattern can not be correct without a very special bulb and no company is going to invest in that bulb for very few sales. All kits use a "stock" HID bulb made for some car use, most kits modify them so the original lamp won't fit in the kit adapter. It's very possible that getting a replacement bulb that fits will be near impossible, the manufacturers of the cheap kits come and go. No "brand name" company makes an H4 HID conversion... I've seen name brand kits but these were fakes - same crap in a box with a name brand printed on it.
If you want an HID lamp, find an HID lamp assembly from some car and adapt it. If you want bright driving lamps there are HID ones available, they cost $$$ but turn night into day ahead.
On a 750 there is plenty of electricity available to run a 55/65W  H4 headlight. Smaller bikes, not so good. Don't try to use the off-road high wattage bulbs. Smaller bikes can use low-wattage (35/35 or 35/50) H4 bulbs in a conversion lamp: the light on the road will still be way better than with the feeb-o-dim stock unit.
Offline cben750f0
« Reply #14 on: July 13, 2011, 05:01:33 AM »
i modified the mounting ring in my headlight , to accept a 7' H4 housing, with parker. works well for me.
peace
« Reply #15 on: July 13, 2011, 05:29:08 AM »
Bingo.
Adapt a current car lamp with the projector, preferably a passenger side projector/bulb.
Offline Holden
« Reply #16 on: July 13, 2011, 06:22:08 AM »
Why would you like being a dick?  Anyway, the more you compromise the vision of oncoming drivers, the less likely they'll be able to judge exactly where you are, which seems more dangerous to you.  Additionally, putting a true HID system (some fancy-colored H4 bulbs are marketed as "HID") in an H4 reflector doesn't take full advantage of the HID's superior light output.
A motorcycle-specific or passenger-side reflector unit with with an H4 bulb or a true HID system with proper projector unit are the only ways to upgrade.  With a true HID system, you'll have to figure out a place to put the ballast.
« Last Edit: July 13, 2011, 07:54:56 AM by Holden »
Offline Radam
  • taco racer
« Reply #17 on: July 13, 2011, 06:47:36 AM »
Anyway, back to the original poster. Wilson, the link that you posted has headlamps that are safe to use in your bike without being a dick. As I said before I have one in my bike. On high beam it doesn't blind oncoming traffic. It is probably the best/easiest thing you can do for the least amount of money. And it's a Halogen not HID. Still 10x better than the stock bulb.
Offline willbird
« Reply #18 on: July 13, 2011, 09:35:44 AM »
Also lots easier to carry a spare bulb :-)...not sure how long they will live carried on the bike somewhere though ? When I put mine in both the high and low burnt out on me, right at dusk, had to make a mad dash home. Not sure why, Action fours sent me a new bulb and it has been fine since.
« Reply #19 on: July 13, 2011, 10:06:58 AM »
Well that's the other thing. HID's are more vibration resistant. How do I know? Because in my
Buell the bulbs blew out in about 3k miles. Still on the original HID replacement bulb in 12k miles. You just need a good refractor in the lens. I have HID's in all of my vehicles and they are just right. Not too bright but way better than factory. No people ever flash me, and no cops pull me over. Don't get me wrong someone with a 55w (versus my 35w) with a nice neon purple color is annoying but it never impairs my ability to see where they are on the street. When cops pull you over they blast a spot light in your eyes and mirrors and then they let you drive on off seconds later. Isn't that just as dangerous then?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline cb550inct
  • I am really good at buying parts
« Reply #20 on: July 13, 2011, 10:28:30 AM »
I bought a Bosch halogen kit for a 550 I love it, easy to put in , and much brighter...is that the reponse to the post you were looking for
1978 cb550k
1998 Harley Springer Softail
2004 Harley Heritage Softtail (sold)
2001 Vespa 150 (sold)
1980 Kawasaki Kx 80  (first Bike)
Offline oldk6guy
  • old bike
  • is this ever really done?!
« Reply #21 on: July 13, 2011, 10:32:27 AM »
this is what i bought
http://cgi.ebay.com/ebaymotors/35W-Motorcycle-BI-Xenon-HID-headlight-Kit-H4-H-L-10000K-/270734864108?pt=Motorcycles_Parts_Accessories&hash=item3f090e2eec#ht_2767wt_939
and i bought this to put it in
http://cgi.ebay.com/ebaymotors/7-DOT-H4-MOTORCYCLE-HEADLIGHT-HARLEY-HONDA-YAMAHA-/330471962590?pt=Motorcycles_Parts_Accessories&hash=item4cf1a9f7de#ht_2299wt_1165
the beam is nice and flat, and the bi-xenon function simply moves the bulb within the housing so that the beam points down more on the low beam setting.
put together it looks like this
« Last Edit: July 13, 2011, 10:37:19 AM by k5streetfighter »
76 cb750 k6: 4 into 4 exhaust, open air horns on carbs.
Offline Really?
« Reply #22 on: July 13, 2011, 10:42:19 AM »
Okay, so I have read this thread a couple times.........
I want plug and play.  So, what is/are the right item(s) to get.  Links please.  ;D ;D
I have seen K5's last post.
What I do get out of this this thread is what's nice and not so nice.  What I did and what I did and what I did.  I guess I must still be on vacation from last week and my mind is still out in the hill country.
I do not ride at night much anymore so I am nowhere near in any hurry.  Besides, I have a foam and seat cover to put on the bike still.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline wannabridin
  • -Garrett
« Reply #23 on: July 13, 2011, 10:47:27 AM »
you want plug n play HID or halogen??
Offline wilson889
« Reply #24 on: July 13, 2011, 10:50:01 AM »
Where did you end up hiding all that wiring??
1975 Honda CB 750K
