Author Topic: Vinyl Repair Advice...  (Read 1676 times)
Offline wheelie
« on: April 29, 2006, 08:42:18 AM »
Any thoughts on how to keep this tear from expanding and the foam getting wet until I save up for a pro recover? This is the condition of the seat when I purchased the rig earlier this year.
1978 CB750K
...The significant problems we have cannot be solved at the same level of thinking with which we created them.
        -Albert Einstein
http://www.sohc4.us/gallery/v/members/personal/wheelie/
Offline wheelie
Re: Vinyl Repair Advice...
« Reply #1 on: April 29, 2006, 08:43:10 AM »
And a close-up....
1978 CB750K
        -Albert Einstein
CB925
« Reply #2 on: April 29, 2006, 09:02:04 AM »
This may make you shudder, and horrify you to your very soul, but as a short term "patch" duct tape can be quite effective.  It will look ordinary, but as you have suggested, you need to keep the moisture out of the seat.
As for vinyl repair kits, I've never tried one, but I imagine any kind of external patch is going to look ordinary.
Offline putnaja1
  • '77 CB 550k -Was gonna cafe, but looks cool stock!
    • Jason's Wacky Website
« Reply #3 on: April 29, 2006, 09:53:50 AM »
First, let me just say that I am no vinyl upholstry wizard by any means..  I've made a couple of small repairs myself (until a recover could be done) and had pretty good results using superglue!  I've also heard of some stuff called "Wetsuit Weld" that comes in a tube- that's probably an even better bet..
For that seat, I'd look around and see if I could get my hands on an additional strip of vinyl, to use inside the seat as a way to bind the side of the seat to the top of the seat..  1st, I'd superglue half of the strip (length ways) to the side of the seat (on the inside), with the other half of the strip sticking up through the rip.  Once that was dry and holding (maybe use a little tape inside to hold it while it is drying..), I'd glue the other half of the vinyl stip to the inside of the top of the seat.  You will probably have to tape the outside of the seat temporarily, and probably try to tape the seam inside if you can, so that when you press the joint together the tape will get stuck (on the inside) and reinforce your joint.
It just might work pretty well!  I know I've seen thick wetsuits fixed and hold together like new with the wetsuit weld, and on my car seat and a leather chair I fixed a small tear in, the superglue held up pretty well, although was harder than the surrounding material obviously.
Jason
Play Pinball!
My Gallery!
"The world is divided into people who do things, people who get the credit and people who continually criticize.  Try, if you can, to belong to the first class of people.  There's far less competition"
« Reply #4 on: April 29, 2006, 10:58:53 AM »
The only permanent fix is to replace.
To save the foam, however, you can patch it from the inside.
It is as much or more work than replacing the cover, as to patch from the inside it must be removed.
Once removed, find a piece of cloth reinforced vinyl, and cut it four inches longer than the split length and 4 inches wide.  The idea is to have a 2 inch overlap around the entire tear and you will glue the cloth side to the cloth inner side.
Get a product called Shoe Goo (hobby stores, shoe repair).  It is as flexible as vinyl and quite tenacious on clean surfaces.  Then arrange the seat cover on your bench or buck, so the repair area is flat and you can fit a caul and weight over the area to press the patch onto the tear.
To hold the seam together before the gluing process, you could use painters blue tape if there will be little stress while clamped, and carpet tape if there will be higher stress during the clamping. Either of these tapes will be applied temporarily on the outside during the repair process.  Clear packing tape might let you see the seams appearance before gluing, but I didn't try that.
When everything is all set up for clamping.  Apply the Shoe-Goo to the patch and put it in place as quickly as possible, then clamp.
This method worked so well for me that it never split at that point again.  A week later it split on the other side.  I repaired that in the same way.  A week after that it split down the middle of the seat.  Repaired.  Another week a new split slightly off center to the left.  Repaired. Then another one slightly to the right.  This process repeated until I had patches overlapping patches.  When, the weather got colder the splits began to work their way towards the back of the seat.  None of the patches ever came loose.
I bought a replacement cover and haven't patched anymore since.  I did save the foam, though.
Best of luck!
Offline KB02
« Reply #5 on: April 29, 2006, 01:37:04 PM »
http://www.crc2onlinecatalog.com/seat_covers.htm
Use the Duct tape for a temporary patch, but if you plan to spend any time or effort into patching it, go ahead and order the replacment skin. You'll be much happier with the results.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
CB925
« Reply #6 on: April 29, 2006, 04:12:54 PM »
yep I agree KB, would look tacky, but will preserve whats inside.  Some cool suggestions in this thread, but as the posters wrote, more effort than actually replacing the whole cover.
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #7 on: April 29, 2006, 07:18:05 PM »
any recomendations for new seat cover sources?  I'd like to keep the origional pattern or go leather.
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline oldbiker
  • I HATE RAIN
« Reply #8 on: April 30, 2006, 01:38:54 AM »
Some time ago when money was particularly tight, I had a similar problem. I begged some offcut material from a local upholsterer for the price of a pint. Carefully take the old seat cover apart and cut new pieces using the old ones as patterns. Use the wifes sewing machine to re-assemble the seat cover and use some wax to seal the needle holes. New seat cover for almost nothing.
