Author Topic: '76 cb550 tail light issue. Help Please!!!  (Read 3308 times)
Offline msalgado44
« on: July 13, 2011, 05:08:38 PM »
Hello all! I own a 1976 CB 550, and am having issues with the tail light. The brake light activates, and the tailight works in the Acc position on the keyswitch, but I cannot get it to activate during normal running. The harness and light is stock, I beleive everything is correctly connected (According to my Honda Wiring diagram). Luckily here in NC this bike is too old for a safety inspection, so I wont fail, but I would like to ride at night and not get a ticket, since you cant read the license plate! Any body have some advice? Thanks!
KingCustomCycles.com
Re: '76 cb550 tail light issue. Help Please!!!
« Reply #1 on: July 13, 2011, 05:11:28 PM »
Got the same problem on my 69 CB750.  I was going to spend a few minutes tracing down the open wire then if that failed just run a new brown wire from another key switched positive source and be done with it.
Offline msalgado44
« Reply #2 on: July 13, 2011, 05:18:16 PM »
Could that taillight be spliced into the headlight circuit?
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #3 on: July 13, 2011, 05:19:41 PM »
Just a thought:  have you checked to make sure the ground wire has a solid connection?  When I replaced my tail light on my '76 550k I had all sorts of weirdness (on when power, off when I hit the brakes). Turned out the ground wire wasn't making good contact.
Good luck
Scott
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
« Reply #4 on: July 13, 2011, 05:20:04 PM »
Yes, any switched positive will correct the problem.
Offline msalgado44
« Reply #5 on: July 13, 2011, 05:24:57 PM »
All grounds are solid I beleive. May try splicing into headlight... Three wires lead to the rear ligh assembly any ideas which operates the running light? I know green is ground, ithink there is also a brown and striped wire? Is Brown the running light?
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #6 on: July 13, 2011, 05:26:42 PM »
Just try it both ways - you'll know in seconds which is correct. I can't remember and I'm not in front of my bike.
~Sophocles
Offline msalgado44
« Reply #7 on: July 13, 2011, 06:28:13 PM »
We have lift off! Perfect solution of splicing into the headlight circuit. On my '76 there just happens to be a spare brown wire in the headlight bucket, some sort of euro spec option for parking I think. Cut off the end, tied onto blue headlight wire since I always keep hi beam on and Voila! We have a fully functioning tail light. Thanks for the suggestions all!
Offline lone*X
« Reply #8 on: July 13, 2011, 06:30:57 PM »
Sounds like you need a wiring diagram and some manuals.  Their free on this site.  Wiring diagrams will let you trace the tail light wiring and possible find the gremlin.  Better to fix it correctly than be someone else's PO.
http://www.sohc4.net/?page_id=207
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline msalgado44
« Reply #9 on: July 13, 2011, 06:47:28 PM »
Since i now have power to the light i am thinking the issue was my keyswitch, i plan on replacing it, however I have to have it inspected for roadworthiness tomorrow and was in a bind to get it don asap. As you can read above i DO have a digram and manual which is how I made this repair and know I need a new keyswitch. As to being someone's next PO, i got this project as a gift from my
Dad, and plan on keeping it for a long time (read as Forever). Thanks for the advice.
Offline lone*X
« Reply #10 on: July 13, 2011, 07:14:38 PM »
Gotcha.  Temporary fix is OK.  Keeping it in the family is a good thing too.  Still have my 75k1 which I purchased new so I know how that works.  My only concern was that we read so often about the suprises that new owners find in the wiring harness from "fixes" by the previous owner.  It's always best to get it right.
Lone*X  ( Don )
75 CB550K1
Offline stidds
« Reply #11 on: July 17, 2011, 02:44:34 PM »
Glad you sorted you problem, I was going to add though (and you have already though of it) that I had exactly the same problem with my 550K and the problem was the keyswitch, I replaced it and everything worked well.
Offline Spanner 1
« Reply #12 on: July 18, 2011, 06:42:48 AM »
The actual fix is that the taillight fuse is blown/ not connecting in it's holder/ corroded. The brake light is not powered thru' the taillight fuse, so thats why it still worked and with the key in 'park' position the taillight is powered by the main fuse, not the taillight fuse.....  :) ;)
Offline n8dogg2000g
« Reply #13 on: February 12, 2012, 07:01:50 AM »
This is not true for my 76 CB550 (which I believe is relatively stock..but who knows).  If the tail light fuse is blown, the tail light will not light in the 'on' or 'park' position, but the brake light will light.  I had the same issue as msalgado44, the fix was retracing the wiring inside the headlight.  The previous owner had several black wires hooked up to the wrong connector (there are two separate connectors for the black wires that have to be correct for the tail/tach/speedo lights to work).
76 CB550
80 CX500
99 YZF R6 (supplements my need to cut up a perfectly good old honda and try and make it a sport bike)
bollingball
« Reply #14 on: February 12, 2012, 12:42:45 PM »
Better 7 months late than never ;D
