Author Topic: Spirit 750 street tracker, SO MUCH FUN!!!  (Read 7370 times)
Offline wannabridin
  • Patience made me a
  • -Garrett
« on: July 14, 2011, 02:21:06 AM »
Hello all! Just wanted to ask a few quick questions, for my latest incarnation of my bike!
I have a 2010 r6 front end (everything!) and I want to put it on the spirit. I haven't done any disassembly on the spirit yet, so I'm not 100% on how everything will work out dimension wise. Im not worried about the bearings, all balls has those covered. I'm wondering if anyone knows about a way to raise the suspension on an inverted front end like that without negating it's handling characteristics...
Also, I'm going to switch to a monoshock rear end. Add shock mounts to the rear boxed frame section, reinforce the swingarm and hopefully everything will be ok! I don't want to use anything fancy on the rear end geometry wise, just a decent adjustable shock to compliment the grit setup!!
Add some dirt bike bars, rearsets, high pipes and a tracker tail section, I should be ready to rock!! Thoughts please!!
« Last Edit: November 17, 2012, 08:03:34 PM by wannabridin »
Offline wannabridin
  • -Garrett
Re: Spirit 750 street tracker
« Reply #1 on: July 14, 2011, 12:50:50 PM »
Ok, problems seem to be arising from the changes in frame geometry.  By raisin the rear end, I'll reduce my trail some.  But the biggest hurdle will be making sure the trail is proper for the front end.
The r6 is slightly shorter than the spirits, I think.  I'll know once I attempt to swap the front ends, but I'm just wondering what everyone's ideas are for increasing trail on a bike.  I'm having troubles finding some fork extensions (50mm or so) and I could also run a taller tire.
I'd love to have as much ground clearance as possible for handling characteristics, so this is important to get right!!
Offline Alan F.
« Reply #2 on: August 01, 2011, 06:54:17 PM »
Raising the front is one way to increase trail, but you could also lower the rear with shorter shocks, a lower aspect tire, or a smaller diameter tire.
Offline wannabridin
  • -Garrett
« Reply #3 on: August 08, 2011, 09:43:50 AM »
ya, i considered that too, but i think the trail would just change too much frankly...  as killer as it would have been to have twin floating discs, i'm going to stick with spoke wheels, and i'll upgrade the front brake to a full EBC floating setup.  that will give me plenty of stopping power up there.  i'll also do a racetech front end on it, and probably put the stock fork brace on with a small fender to help keep things stiff!
i've been talking to a guy on another forum, and he said that with a gt650 or vt1100 carb swap, i could pick up a good bit of power.  like 130 in 4th gear!  (granted he had cams and pistons, which i plan on eventually as well!)
i will def. throw a monoshock on the rear though.  reinforce the swingarm, add a top mount to the rear framerail and rebuild the subframe to accept a seat and sit higher.  all in all, should be a VERY fun bike!
Offline wannabridin
  • -Garrett
« Reply #4 on: August 20, 2011, 10:57:09 PM »
I think I'm going with a gulf oil paint scheme...  Always wanted one, nows my chance!!
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: August 22, 2011, 09:26:52 AM »
Go for it. i seem to recall seeing someone on the project bike threadthat had one on their bike. It was amazingly cool.
Offline Bankerdanny
« Reply #6 on: August 22, 2011, 09:28:58 AM »
Offline wannabridin
  • -Garrett
« Reply #7 on: August 22, 2011, 01:02:49 PM »
i remember seeing that thread.  thanks for re-posting it.  spirit will get some work started "soon".  it's all so relative at this point anyways, with school trying to finish up and the job search going on.  funds are practically non-existent nowadays...
Offline lucky
« Reply #8 on: August 23, 2011, 04:51:07 PM »
WHY would you change to a monoshock rear swing arm? It is harder to work on.
It is more expensive. The two shock set up is easy to work on and you can get shocks much less expensively. Then you will have to redesign the frame AND the swing arm to take the single point load. Makes no sense.
Offline lucky
« Reply #9 on: August 23, 2011, 04:58:02 PM »
Raising the FRONT will increase the rake. Lowering the REAR will increase the rake.
But not by very much. 1ยบ maybe. Nothing.  Trail will increase a little, not much.
Offline wannabridin
  • -Garrett
« Reply #10 on: August 23, 2011, 09:04:53 PM »
i want the monoshock because it's unique and i can get the shock for free from a 2010 r6, so it should be more than adequate of handling the suspension loads.
engineering it won't be too terribly difficult, i've already looked into it.  i can add a reinforcement plate to the swingarm, and on the rear downard framerail i can add the top mount rather easily too.
suspension should be just fine, and the rear end will stay super clean, again making for quite a unique build!
Offline wannabridin
  • -Garrett
« Reply #11 on: October 06, 2011, 09:47:07 AM »
First step, dirt bike bars:
Offline lucky
« Reply #12 on: October 06, 2011, 01:42:47 PM »
That yamaha R6 front triple trees have less offset so it will have less leverage when you turn. Why do you think they had to have a steering damper on all those sport bikes?
Very little rake and not much trail.
I would leave it alone.
Work on more important stuff.
It is NOT a sport bike.
You cannot make it a sport bike just because you add a Yamaha R6 front end.
Just spray paint some of your parts gold and you will feel better right away.
Use the gold CARB paint from Eastwood so it does not look like cheap gold spray paint.
Your friends will think you are still all right.
You got carbon things-CHECK,you got gold anodized looking stuff- CHECK, You got stickers and decals- CHECK. LOL....LOL
Offline wannabridin
  • -Garrett
« Reply #13 on: October 06, 2011, 05:08:42 PM »
Haha, ya I gave up on the sport bile front end, I'm just going to give the front end a full racetech treatment and the rear end either a modern sport bike monoshock (free+fab work) or some ikon shocks.  If I go the latter route, it'll be an identical setup as the CB! :)
Offline wannabridin
  • -Garrett
« Reply #14 on: October 13, 2011, 06:01:48 PM »
Ok, here's my Rearsets.  First picture is of version 1 using the adjustable mounts, but I didn't like it, so I redid it in a stronger and simpler way, which are the other 3 pictures.
No, routing things is easy when you don't have a sprocket cover or care about things being super hidden!!  Lemme know what y'all think!
Offline wannabridin
  • -Garrett
« Reply #15 on: October 16, 2011, 10:08:42 AM »
i'm going to base my exhaust on this:
Offline wannabridin
  • -Garrett
« Reply #16 on: October 25, 2011, 08:01:26 PM »
Got the exhaust mocked up, just need to do some final finishing before paint, then support the muffler.
Offline wannabridin
  • -Garrett
« Reply #17 on: November 01, 2011, 08:15:15 PM »
got the exhaust mounted up and electrics sorted out.  i think it sounds pretty damn good and looks equally good!  thoughts??
http://youtu.be/MEAj30w-hrU
« Last Edit: November 01, 2011, 08:17:14 PM by wannabridin »
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #18 on: November 01, 2011, 08:21:51 PM »
Looking good homie.
Offline wannabridin
  • -Garrett
« Reply #19 on: May 29, 2012, 10:29:41 AM »
sorry i haven't posted any new updates, i need to get some on here.  got the subframe fabbed up, seat mounted, exhaust sorted out, longer shocks installed, etc, etc.
now need to search for a possible air/vac leak in the intake and then take it to the dyno to get it dialed in.  it sounds MEAN, and is a lot of fun to throw around!!  it's really cool too, because there isn't another honda cruiser around that's built like this!  (at least not that i've seen locally or on the net, which doesn't mean they don't exist)
either way, pictures to come soon, along with some updated sound clips!
Offline wannabridin
  • -Garrett
« Reply #20 on: June 07, 2012, 02:13:41 PM »
this thing is a freggin BLAST to ride!!  i can't believe how well this frame can handle, i just need to get some new tires, chain, sprockets and finish up a lot of little things!  hopefully i'll have to lift table set up ASAP and i can get working!
Offline Flying J
« Reply #21 on: June 07, 2012, 06:17:53 PM »
That is looking amazing. Cant wait to see where it goes from here.
Offline wannabridin
  • -Garrett
« Reply #22 on: June 07, 2012, 10:38:04 PM »
Oh it looks a lot better than those pics!  I can't seem to get oover just HOW Badass it looks in ANY setting!  I rode it over to a friends house the other day and caught myself stopping at the window and just staring aat it!  I haven'had a bike do that awhile!  At least not iin person!  So.needless to say, I'm quite happy with my work so far!  :-D
« Reply #23 on: June 07, 2012, 11:08:01 PM »
WELLLLLLLLLLLLLLLLL    post some friggin pics FFS....... ;D ;)
Offline wannabridin
  • -Garrett
« Reply #24 on: June 08, 2012, 10:22:13 AM »
i will asap!  i just moved into a new place with the girl, so i need to get the garage cleaned up some, which i'm planning on this weekend.  i'll get some posted soon.
